tingshen
Kronotex Ac5 430ft Package At $2599 (free 20ft)
kronotex salesman tell me whether its 8mm or 12mm will also warp.. because of expansion and contraction.
typically warping will be at the ends.
but the engineered floorboard will not.. apparently because its a different joint system.
but the engineered floorboard is more swee...
My AC4 ... No. 32 had started to warp ..
It installed around Nov 06... now is only Apr 2007. ...
OMG!! is that kronotex? more like workmanship problem.....
Yes,,,... it is ...
I guess so. ID asked got Guarantee/Warrantly for 3 years... so not too worry.
I only worry / paiseh to trouble ppl.
i think what they meant was workmanship warranty is 3 years.
product warranty is > 15 years one.
shld be lah
A few questions hope you guys can help me here
1. Laminate vs Parquet. Pros and Cons.
2. Cost of laminating 1 room vs 3rooms. My ID told me that it's not cost effective to laminate 1 room as compared to 3 rooms
3. IF I'm going for lamination, is Kronotex the only provider.
Cheers.
Cheers.
1. Both have its pro and cons. But still it is also up to the owner how well they can maintain it. No matter how good is the quality nor the thickness without proper maintaince or care from the owner end out effect will be cons more than pros.
2. due to more rooms are being laminated therefore will be cheaper.
3. kronotex is not the only provider. There are quite a few brands out there. :)
