Is This Amount Quoted For Carpentry Of Walk In Closet Reasonable?
My carpenter has quoted me the below for walk in closets. Somehow, i find it abit steep because it almost reaching 100k. Is the price fair or ? Any experts able to guide me how much is consider reasonable or how do we gauge the price?
Your advise and sharing is much appreciated. Thanks !!!
CARPENTRY WORK FOR WALK IN CLOSETS
PROFESSIONAL SERVICE
1 Design consultation & space planning. $ -
2 Perspective drawing on all carpentry works. $ -
3 Project management & job site supervision. $ -
4 Material & colour scheme proposal. $ -
5 Submission of HDB renovation permit. ( Exclude permit fees ) $ -
6 Arrangement for installation of power gas piping. $ -
BEDROOM 2 (2nd Floor)
Carpentry Works
1. Design & fabricate 20ft(L) x 600mm(D) x 8.5(H) solid plywood wardrobe open Concept c/w necessary accessories w/ laminate & internal Vinyl finishing as per design proposed at bedroom 2. $ 13,000.00
2. Supply & install 6 nos of blumotion runner. $ 480.00
BEDROOM 3 (2nd Floor)
Carpentry Works
1. Design & fabricate 27ft(L) x 600mm(D) x 8.5(H) solid plywood wardrobe open Concept c/w necessary accessories w/ laminate & internal Vinyl finishing as per design proposed at bedroom 3.
$17,550.00
2. Design & fabricate 3.5ft(L) x 100mm(D) x 8.5(H) solid plywood feature wall c/w door w/ laminate finishing as per design proposed at bedroom 3.
$875.00.
3. Supply & install 6 nos of blumotion runner. $ 480.00
BEDROOM 5 (3rd Floor)
Carpentry Works
1. Design & fabricate 20ft(L) x 600mm(D) x 8.5(H) solid plywood wardrobe open Concept c/w necessary accessories w/ laminate & internal Vinyl finishing as per design proposed at bedroom 5.
$13,000.00
BEDROOM 6 (3rd Floor)
Carpentry Works
1. Design & fabricate 20ft(L) x 600mm(D) x 8.5(H) solid plywood wardrobe open Concept c/w necessary accessories w/ laminate & internal Vinyl finishing as per design proposed at bedroom 6.
$13,000.00
2. Design & fabricate 3.5ft(L) x 8.5(H) solid plywood door c/w mirror, top & bottom clip sliding track in laminate finishing as per design ptoposed at bedroom 6. $1,350.00
3. Design & fabricate 4.5ft(L) x 100mm(D) x 8.5(H) solid plywood feature wall c/w 7 nos of 1000mm(L) x 60mm thickness x 400mm (D) shelving in glass and laminate finishing as per design proposed at bedroom 6. $3,825.00
4. Supply & install 6 nos of blumotion runner. $ 480.00
ATTIC FLOOR
Carpentry Works
1. Design & fabricate 37ft(L) x 600mm(D) x 11.5(H) solid plywood wardrobe open Concept c/w necessary accessories w/ laminate & internal Vinyl finishing as per design proposed at bedroom 6.
$27,750.00
Total Renovation Amount : $92,750.00
Grand Total : $92,750.00
Looks like serious Chop Chop to me :no: plywood with vinyl back are low cost material, that's a straight giveaway.
wow...so expensive. Check out www.sgcloset.com They specialise in stainless steel wardrobe and cabinet which is very classy and high resistence to corrosion. They have a showroom at Geylang which you can check it out. Contractor tends to quote high for their design and they so-called workmanship but common.. Check this out as I think boutique style wardrobe will be the new trend instead of the boring plywood. I did my walkin wardrobe in plywood but if I have the $ now, I will re-do and changed it to stainless steel. my 2 cents count
Thanks Guys..
I will most probably review and look for alternative.
The price all look quite steep to me too`~
If you have recommendations, feel free to pm me. Thanks in advaance
hi,
u can try my contactor.
he just doing carpentry works.
is direct factory.
try to give him quote good luck.
86971294 john
