dean 5 Report post Posted September 30, 2013 (edited) where to buy fiberglass diy mosquito net? Edited October 8, 2013 by dean Share this post Link to post Share on other sites
w7_lee 11 Report post Posted November 5, 2013 I bought mine from a local seller which I found on the internet.Link below for your reference.http://www.magneticinsectscreen.blogspot.sg/ Share this post Link to post Share on other sites
SKYJUICE123 0 Report post Posted December 3, 2013 one does not need any PVC strip if one uses the DIY mosquito net from ebay.. they provide a Velcro strip to hold onto the net.. the net when when complete is transparent whether in black or in white color. The correct way to install these net is to just lay them to the Velcro strip without stretching the net.. this way, the Velcro will stick to clean surface or else, they might just "tear".. I have used this for my house..http://skyjuiceiswater.blogspot.sg/2013/06/diy-mosquito-screens.html Share this post Link to post Share on other sites
dean 5 Report post Posted December 5, 2013 I bought mine from a local seller which I found on the internet.Link below for your reference.http://www.magneticinsectscreen.blogspot.sg/I also bought 1st version from same seller. Cost $39. 2 toilet window with magnetic mosquite fiber mesh net. Corner clip easy crack. Share this post Link to post Share on other sites
dean 5 Report post Posted December 5, 2013 (edited) one does not need any PVC strip if one uses the DIY mosquito net from ebay.. they provide a Velcro strip to hold onto the net.. the net when when complete is transparent whether in black or in white color. The correct way to install these net is to just lay them to the Velcro strip without stretching the net.. this way, the Velcro will stick to clean surface or else, they might just "tear".. I have used this for my house..http://skyjuiceiswater.blogspot.sg/2013/06/diy-mosquito-screens.htmlVelrco strap no good material cheap clothes net those shop selling $3.50.The cheapest diy way for bedroom window buy 5x4" fiberglass mosquito mesh net (grey or brown) from $17 (mustafa) or $17.90 (home fix) and 3pcs 10mm x 3 metre magnetic adhesive tape $2 each, super strong double sided adhesive tape 10mm $1.50, brown/blue tape 6 metre $2 so total cost $17+6+1.5+2=$26.50sgdThere's only 1 type fiberglass mosquito mesh net Homefix and Mustafa. 10mm magnetic tape adhesive tape not strong enough, so need to paste super strong double sided adhesive tape. Edited December 7, 2013 by dean Share this post Link to post Share on other sites
SKYJUICE123 0 Report post Posted December 6, 2013 where you get the 3 metre magnetic strip for $2/= each.. most will sell about $10/=; also they will need steel strap to stick. The mosquito nets, are they transparent when fitted?Velrco strap no good material cheap clothes net those shop selling $3.50.The cheapest diy way for bedroom window buy 5x4" mosquito fiber mesh net (grey or brown) from $17 (mustafa) or $17.90 (home fix) and 3x3m magnetic strip $2 each, super strong double side tape $1.50, brown sticker tape $2 so total cost $17+6+1.5+2=$26.50sgd Share this post Link to post Share on other sites
dean 5 Report post Posted December 7, 2013 where you get the 3 metre magnetic strip for $2/= each.. most will sell about $10/=; also they will need steel strap to stick. The mosquito nets, are they transparent when fitted?go homefix or mustafa see fiberglass mesh mosquito net cost $17++. woven mosquito net cannot open ur window.it is magnetic adhesive tape to paste at your window frame and fiberglass mesh mosquito net.below fiberglass mesh mosquito net https://www.google.com.sg/search?q=fibreglass+mosquito+net&source=lnms&tbm=isch&sa=X&ei=RgqjUvf7GIeFrAfjsYDACA&ved=0CAcQ_AUoAQ&biw=1280&bih=668 Share this post Link to post Share on other sites
w7_lee 11 Report post Posted December 10, 2013 I also bought 1st version from same seller. Cost $39. 2 toilet window with magnetic mosquite fiber mesh net. Corner clip easy crack.Think I've use mine for 9 months nows. The corner clips not giving me any problem. And I've remove them to flush at least once during the 9 months. But you could just replace with new clips.Regarding the velcro type, I agree with you. My colleague use it as they ar cheaper and 3 months later, they took it all off. I guess it is OK if you use the velcro type in a window that will not need (or hardly need) to remove for access. Share this post Link to post Share on other sites
SKYJUICE123 0 Report post Posted December 12, 2013 Seen the ones in homefix.. not quite transparent though it is much thicker.. than those magnetic tape are expensive..go homefix or mustafa see fiberglass mesh mosquito net cost $17++. woven mosquito net cannot open ur window.it is magnetic adhesive tape to paste at your window frame and fiberglass mesh mosquito net.below fiberglass mesh mosquito net https://www.google.com.sg/search?q=fibreglass+mosquito+net&source=lnms&tbm=isch&sa=X&ei=RgqjUvf7GIeFrAfjsYDACA&ved=0CAcQ_AUoAQ&biw=1280&bih=668 Share this post Link to post Share on other sites
