cookiegal
Stove And Basin
I heard that Stove and basin are not supposed to be side by side or facing each other.
What about have a stove and basin at the same side byt in between there is a gap of 800mm?
Hi Cookie,
Oven has a sitting and facing direction, to my knowledge and practice according to the star plate mountain stars and water stars (座向星盘) and also door don't face oven,oven don't face toilet bowl,don't face dustbin.
Sitting on 1 mountain star, bad
Sitting on 2 mountain star, bad
Sitting on 3 mountain star, good
Sitting on 4 mountain star, good
Sitting on 5 mountain star, super bad
Sitting on 6 mountain star, bad
Sitting on 7 mountain star, bad
Sitting on 8 mountain star, good
Sitting on 9 mountain star, fire too strong bad.
Facing 1 water star, good
Facing 2 water star, bad
Facing 3 water star, good
Facing 4 water star, good
Facing 5 water star, bad
Facing 6 water star, bad
Facing 7 water star, bad
Facing 8 water star, good
Facing 9 water star, bad
Basin and oven side by side is ok. Oven is one of the important feature in FS. Above placement depends on which stars is the feature stars in the 元运。If 元运, 3 or 4 stars as the feature stars (当令)then oven will deteriorate the feature lucky stars. The above sit and facing list is according to current 元运.
Cheers.
Edited by midasls
Is your "oven" referring to "cooking stove" ?
My "cooking stove" is facing the basin (I assume this is the place where plates are wash) ?
If the design is like this, does the owner needs to renovate ?
Could you be more descriptive ?
Hey Kali,
Yes sorry my mistake its cooking stove,thanks for correcting me. Firstly cooking stove facing basin, to my knowledge is nothing wrong and need not renovate, depends on FS practice. To my knowledge stove placement depends on the star plate (星盘),and even star plate we have different ways of viewing it. My practice is one room one star plate, and all star plate same as living room.
Cheers.
Hey Kali,
Cheers.
I read magazines and heard talks by masters during festive season that stove should not face basin. Would you like to help explain why you said "is nothing wrong".
And if you can substantiate that there "is nothing wrong", then other masters may be wrong, is that right?
Isn't oven the same as cooking stove or I mean similar or equally important?
As I have said it, depends on practices, different people practice different FS. To my knowledge and practice there is nothing wrong. cos a plot of land have different qi at different sector, and putting an object in any sector depends on the qi in the sector. I'd attached a star plate, the small numbers are what we call qi in different sectors (定量之卦气), left small numbers is mountain stars and right small numbers is water stars.
Cheers.
currenCsup1BcopydegcurrensyenOgravebrvba
Edited by midasls
Yes you are right, but whats is being use more on a daily basis ? Stove or oven ?
Cheers.
So what is this for, how to relate to the stove or oven? which number should the stove go for?
so what's the response to this question?
Cheers.
Please read my initial explainantion.
Thanks !
Ooops, where you heard cannot side by side? Mostly are like that rightzzzzz?
Facing each other is always a no, no.
800mm is wide enough liaozzzzz
Hey bro.....cooking stove facing basin? you mean directly opposite si bo? Like that need to change la....how come you got this kind of setting, mostly are side by side le
