tcc 0 Report post Posted August 7, 2013 如何重重克入,位位生来里气?卦象?或--- Share this post Link to post Share on other sites
midasls 0 Report post Posted August 12, 2013 On 8/7/2013 at 9:33 AM, tcc said: 如何重重克入,位位生来里气?卦象?或---后学理解,理气就是峦头,峦头就是理气,气中象,象中气。方圆尖秀,也不出阴阳,五行,八卦,九星之气。理气盘为了寻找新旺气,退气定需移或避。前后,左右,高低,远近。人能感应寒暑或温和之气(干燥或潮湿),能查明象中气。 Share this post Link to post Share on other sites
tcc 0 Report post Posted August 12, 2013 On 8/12/2013 at 2:54 PM, midasls said: 后学理解,理气就是峦头,峦头就是理气,气中象,象中气。方圆尖秀,也不出阴阳,五行,八卦,九星之气。理气盘为了寻找新旺气,退气定需移或避。前后,左右,高低,远近。人能感应寒暑或温和之气(干燥或潮湿),能查明象中气。 Share this post Link to post Share on other sites
tcc 0 Report post Posted August 13, 2013 On 8/12/2013 at 2:54 PM, midasls said: 后学理解,理气就是峦头,峦头就是理气,气中象,象中气。方圆尖秀,也不出阴阳,五行,八卦,九星之气。理气盘为了寻找新旺气,退气定需移或避。前后,左右,高低,远近。人能感应寒暑或温和之气(干燥或潮湿),能查明象中气。理气是挨到的星盘峦头是肉眼看到的形,都可用八卦五行代表是嗎?So don't mix up. So how to use 星盘的理气和峦头戓卦象来重重生入。Thank Share this post Link to post Share on other sites
midasls 0 Report post Posted August 13, 2013 On 8/13/2013 at 12:08 AM, tcc said: 理气是挨到的星盘峦头是肉眼看到的形,都可用八卦五行代表是嗎?So don't mix up. So how to use 星盘的理气和峦头戓卦象来重重生入。Thank生入有很多种类。水路生入,紫白生入,卦象生入(物象),坐向生入。例如“栋入南离”,为39组合,可以由各种形态来生入,例如得水路生入先,若当紫白也同样来往关系生入,效果会来得快,因为得天时。当然也有峦头挨到理气盘得此组合。峦头是可以用八卦五行来代表,杂物堆积得高,为震卦,阳木。因为杂物形势不优美,为负面,不适宜用。如果杂物高而阻塞通路,为坎入震象。如此卦象若挨到理气盘上的坤宫,而有路到,待生事而已。这些是交极端明显的例子。断事难,因为除了卦象之外,也因为分宫不明。九宫并无定位,不可硬分,这是弟的理解。 Share this post Link to post Share on other sites
kcwee 8 Report post Posted August 13, 2013 On 8/13/2013 at 3:34 AM, midasls said: 峦头是可以用八卦五行来代表,杂物堆积得高,为震卦,阳木。因为杂物形势不优美,为负面,不适宜用。如果杂物高而阻塞通路,为坎入震象。如此卦象若挨到理气盘上的坤宫,而有路到,待生事而已。这些是交极端明显的例子。杂物堆积得高, 叫震卦。 那艮卦是拿来踢球?‘坎入震’ 与‘ 震 入坎’是一天一地, 不用分清? Share this post Link to post Share on other sites
kcwee 8 Report post Posted August 13, 2013 On 8/12/2013 at 11:53 PM, tcc said: On 8/12/2013 at 2:54 PM, midasls said: 后学理解,理气就是峦头,峦头就是理气,气中象,象中气。说的没错, 但我要成仙才会唱这种歌。 Share this post Link to post Share on other sites
midasls 0 Report post Posted August 13, 2013 (edited) On 8/13/2013 at 8:02 AM, kcwee said: 杂物堆积得高, 叫震卦。 那艮卦是拿来踢球?‘坎入震’ 与‘ 震 入坎’是一天一地, 不用分清?艮卦?艮卦很难的。。。这个球不容易踢的。我几时话不用分清啊?哈哈。。。。13和31,当然有分别。现在不是震入坎吗?哈哈哈。。。。 Edited August 13, 2013 by midasls Share this post Link to post Share on other sites
tcc 0 Report post Posted August 14, 2013 要踢球不如用乾卦吧?震为雷为动,坎为险----不如用艮卦为止为君子----这样踢了大家都高兴是吗? Share this post Link to post Share on other sites
midasls 0 Report post Posted August 14, 2013 (edited) On 8/14/2013 at 1:28 AM, tcc said: 要踢球不如用乾卦吧?震为雷为动,坎为险----不如用艮卦为止为君子----这样踢了大家都高兴是吗?兄,可能是山水蒙。。。。其实是用了艮卦,只是艮卦负面而已,怨气重。弟也看到兑卦,自我。此话题引动了KC兄的第一爻变,没开始是静态为坤卦,初爻动变了震卦,开始有争斗事件,而震卦颠倒为兑卦,兑为口,口舌争斗是非之事。如果要用艮卦的君子,比较难,因为用的是艮卦的负面性质,就是怨气重,和过于喜欢管制,这可能是因为艮卦虚不受补,所以泄了。仁,仪,礼,智,信,KC兄的仪德(金)是不可否认的足够了。只是愚见。。。提供参考,待讨论。 Edited August 14, 2013 by midasls Share this post Link to post Share on other sites
kcwee 8 Report post Posted August 14, 2013 On 8/13/2013 at 3:34 AM, midasls said: 峦头是可以用八卦五行来代表,杂物堆积得高,为震卦,阳木。因为杂物形势不优美,为负面,不适宜用。。"杂物堆积得高, 叫震卦。 那艮卦是拿来踢球?" 这话是回应你所用的卦, 别转话题。如果堆积高的杂物可为震卦, 那不是动 静不分?不然你再打多一个太极来指教老兄吧。 堆积不动而又高之物何时可用震卦? Share this post Link to post Share on other sites
kcwee 8 Report post Posted August 14, 2013 On 8/13/2013 at 3:34 AM, midasls said: 如果杂物高而阻塞通路,为坎入震象。‘坎入震’ 与‘ 震 入坎’是一天一地, 不用分清? 这话也是回应你的用卦。坎入震 (艮)是先高杂物后搬条路去塞,震(艮)入坎是道路已经存在而后搬杂物去塞。这是不是分不清? Share this post Link to post Share on other sites
midasls 0 Report post Posted August 14, 2013 (edited) On 8/14/2013 at 5:07 AM, kcwee said: ‘坎入震’ 与‘ 震 入坎’是一天一地, 不用分清? 这话也是回应你的用卦。坎入震 (艮)是先高杂物后搬条路去塞,震(艮)入坎是道路已经存在而后搬杂物去塞。这是不是分不清?兄,“后搬条路去塞”?如何搬路去塞?兄的意思是不是,先有杂物堆积(坤),杂物堆积得高(震),然后慢慢延伸出阻塞条路呢?另外就是先坤变坎再起高变震?至于“艮”,后学不敢认同,因为“质”的问题。 Edited August 14, 2013 by midasls Share this post Link to post Share on other sites
midasls 0 Report post Posted August 14, 2013 (edited) On 8/14/2013 at 4:51 AM, kcwee said: "杂物堆积得高, 叫震卦。 那艮卦是拿来踢球?" 这话是回应你所用的卦, 别转话题。如果堆积高的杂物可为震卦, 那不是动 静不分?不然你再打多一个太极来指教老兄吧。 堆积不动而又高之物何时可用震卦?兄,由形质来断。虽然兄的建议为“艮卦”的可能性,但是艮卦的“质”应该不是杂物。后学明白兄之意,因为艮为山,但是山也有很多“形质”,例如一个水晶山,后学不会断是震卦或艮卦,后学会视为“离卦”,而且是非常难看的“离卦”,但是如果这水晶经过加工,出现了水晶雕塑,亮丽的摆设,这就是“离卦”正面。至于动静,我两看事有差异,所以不便解释。我可以是阳,也可以是阴,但何时阳何时阴?我可以是动也可以是静,但何时静何时动?浅见,待讨论。 Edited August 14, 2013 by midasls Share this post Link to post Share on other sites
kcwee 8 Report post Posted August 14, 2013 On 8/14/2013 at 9:47 AM, midasls said: 兄,由形质来断。虽然兄的建议为“艮卦”的可能性,但是艮卦的“质”应该不是杂物。谁能看到是什么杂物?我也可说这些杂物的质不错啊!如要讲下去,艮为土, “质”包好嚒? Share this post Link to post Share on other sites
