midasls 0 Report post Posted September 5, 2013 (edited) FUXI and WEN WANG 伏羲和文王Fuxi 伏羲 observe the weather changes and landscape changes and uses 8 GUA to symbolise them, Wen Wang 文王 act out the 8 GUA . 伏羲观天文查地理而画八卦,文王演绎八卦。 Observe 观察(先天), Act out 演绎 (后天) 。先明白“体”,然后才有“用”。14组合,可以是时间的关系而发生,毕竟在地理用事位是避免用4(巽卦)的卦象,因为不当旺,除了某些情况,这是地理之用。时间好坏在于顺时或逆时,顺则生,逆则亡。天时,地理的用法不同,但是也是对立统一的。坎生巽,是可以的,但是重点在于时间。贪狼在巽宫守候。。。。。。 Edited September 5, 2013 by midasls Share this post Link to post Share on other sites
midasls 0 Report post Posted September 5, 2013 (edited) 坎之生氣,得巽木而附寵聯歡 Edited September 5, 2013 by midasls Share this post Link to post Share on other sites
midasls 0 Report post Posted September 7, 2013 (edited) One Ying One Yang is the way (一阴一阳之谓道)The Way (道) should be link and not be block, is a way to peaceful and meaningful life (通则太平). For both qi to communicate, one have to be ying and the other have to be yang. How do we differentiate Ying and Yang ? Brightness, example colour or lighting. Thats how each Gua is separated into its own ying or yang state, by shapes, brightness, movement, height, etc.巽阴就离。。。49纯阴之象,风吹火熄灭,为有待阳而得风调雨顺。 Edited September 7, 2013 by midasls Share this post Link to post Share on other sites
kcwee 8 Report post Posted September 8, 2013 Trend ( 风气 )In ZhouYi (周易), we have a He Tu (河图),Luo Shu (洛书),both although might be different but both diagram will be consider together when using them, like what are the trend in the society we examine on the 河图运 (甲子水运,丙子火运,戊子木运,庚子金运,壬子土运) together with the 洛书运 (星运),when we talk about 河图运, we will talk about the 5 element luck each lasting 12 years total of 60 years (六十甲子), when we talk about 洛书运, we talk about the stars 1 to 9 with each star luck lasting for 20 years, Both 河图运 and 星运 combine together can actually forecast a society trend (社会风气). FS have to take both 河图洛书 into consideration.wah....not bad huh.....change engine oil liao ahSo you mean "5 element luck each lasting 12 years a total of 60 years " is called 六十甲子? Share this post Link to post Share on other sites
kcwee 8 Report post Posted September 8, 2013 Energy (精神)Energy 精神 is how we interpret a place with good FS, its just like a person who like his or her job and happily working in a company, you can feel his or her vibrant energy in work, its not as simple as the person solely love his or her job, first and foremost the person must find the right place to make him or herself useful or show his or her talent. From then on we can see the person have different colour of qi (气色). Thats why in FS we seek for the colour of spring (春色).紫气东来。。。。Are you sure....some seek the color of gold le Share this post Link to post Share on other sites
kcwee 8 Report post Posted September 8, 2013 Its all translated. Same goes to the poem u give me.How to use ? First identify all your household stuff, which element they belongs to, ying or yang. Then we talk about use. 名揚科第,貪狼星在巽宮贪狼(1) at 巽宫 (southeast palace), but this is not 14 combination to begin with, 贪狼 is the first star in 北斗, it stand for wisdom, 贪狼原来发来迟, meaning this star will bloom late but......long lasting. 天一生水,地二成之, thats the clue to 贪狼.To deal with 贪狼 star is not as easy. 水冷金寒,坎癸不滋乎乾兌, thats what happen if we don't know how to deal with this 贪狼 star. 乾坎,秋冬,Autumn and Winter, therefore its too cold for anything, there is something missing in this combination, as in what is missing? Back to Iching study, these I will not explain further.Cheers !I also layman le....can simplify how to use 1+4 star bo.....can use or cannot use? or use already must wait for very long to happen.....don't keep writing missing link le.....either know or don't know....know just share.....don't know or not willing to share just shut up. Share this post Link to post Share on other sites
kcwee 8 Report post Posted September 8, 2013 No la......still slowly climbing, but thanks !Cheers !wah...you come out of your self-hypnotization liao ah? Share this post Link to post Share on other sites
kcwee 8 Report post Posted September 8, 2013 How come jump here jump there to explain? Shouldn't it be in a flow from top to bottom? Can give some examples what is fake and what is true?Simple lo....because he doesn't know ma Share this post Link to post Share on other sites
kcwee 8 Report post Posted September 8, 2013 1贪狼,is wisdom, 智慧星,而智慧星是由乾卦所生,为16共宗,坎乾两卦有劳动之象征,就是要经过一番磨练才能得才,所以贪狼原来发来迟,wisdom don't come early. 要注意的是,16为纯阳卦,记得要休息和调理身体,例如给中医调理,那休息和中医调理身体是什么卦呢? Thats the missing link.只把天医,福德装。。。。"1贪狼,is wisdom, 智慧星"Are you totally sure? Just 智慧 only? Share this post Link to post Share on other sites
kcwee 8 Report post Posted September 8, 2013 只把天医,福德装。。。。Know what it means...... eh sai explain bo? Share this post Link to post Share on other sites
kcwee 8 Report post Posted September 8, 2013 FUXI and WEN WANG 伏羲和文王Fuxi 伏羲 observe the weather changes and landscape changes and uses 8 GUA to symbolise them, Wen Wang 文王 act out the 8 GUA . 伏羲观天文查地理而画八卦,文王演绎八卦。 Observe 观察(先天), Act out 演绎 (后天) 。先明白“体”,然后才有“用”。14组合,可以是时间的关系而发生,毕竟在地理用事位是避免用4(巽卦)的卦象,因为不当旺,除了某些情况,这是地理之用。时间好坏在于顺时或逆时,顺则生,逆则亡。天时,地理的用法不同,但是也是对立统一的。坎生巽,是可以的,但是重点在于时间。贪狼在巽宫守候。。。。。。wah....clap clap clap le Share this post Link to post Share on other sites
kcwee 8 Report post Posted September 8, 2013 陰陽雖云四路,宗支只有兩家數列五行體用,恩仇始見星分。As said already, everything is ying yang, first identify the body,ying yang and the element then we talk about use. As i have written before, the problem with FS is if we cannot identify the medicine, how we cure ?Harrrrr.....you call this explanation ah.......Is this the actual meaning of the author? Hero liao ah.....everything classic i oso use ying yang explain can liao.Want to explain again the actual meaning of the author? Or don't know? Share this post Link to post Share on other sites
kcwee 8 Report post Posted September 8, 2013 八宮之締合,自有假真。地天為泰,老陰之土生老陽。若坤配兌女,庶妾難投寡母之歡心。澤山為咸,少男之情屬少女。 8 palace match up, there will be true and fake matchkun gua and qian gua match (地天泰),pure yin and pure yang match.kun gua and dui gua match (坤配兑),young concubine (庶妾为兑女) will not make widow(坤为寡母) happy,both belong to yin, dui and kun although is yin gold and yin earth, both element although compliment each other but both are yin gua yin element so will not last long. 澤山為咸, (澤为兑,山为艮)young girl (兑)and young man (艮) are perfect match. 咸卦为64卦里面的澤山,stands for man should respect the woman he love and married her, then 咸(贤)卦 can be completed and be auspicious, this is the start of a family. Cheers !wah bravo la....once a while must praise you tio bo.... Share this post Link to post Share on other sites
midasls 0 Report post Posted September 8, 2013 Parents and kids 父母与子女When both yin yang qi combine together we can see there is a male and female counterpart (雌雄), but yin yang combine with no outcome then there will be no chances (机), until we see a family form up meaning parents and kids (父母与子女). Yin and yang together there is a chance (生机), what we are looking for is a family (化机化育). One can say its a triangular relationship, but its better said as a family.乾坤得生机,待贪狼现形或得气为化育。有生机但是无化育既是有机会但是不能发挥。 Share this post Link to post Share on other sites
midasls 0 Report post Posted September 9, 2013 The End is The Beginning (终始)We all know that any matter will have a beginning and the end, actually the end is another beginning. Like a flower, life of a flower starts when it bloom (开花), ending it wither (掉零),beginning (开始) , the end (终止), thru out this process from start till the end a flower goes thru 9 stages including the beginning. One will always wonder whats the beginning stage of a fruit ? Its not ripe and green just like a kid.一生一成,相为经纬。一阴一阳,相为交媾。九畴从此生,九宫从此配、九星从此挨,而治国经野之道备焉。 Share this post Link to post Share on other sites
