polobear
Can Someone Advise On My Renovations Quotes?
(EXCLUSIVE PACKAGE FOR HDB BTO FLATS)
A (PROFESSIONAL SERVICES)
Space planning & conceptualizing
Furniture planning & products pre-consultation
Project management,site supervision & auditing
3D drawings for all carpentry works
3 years warranty with guarantee after sales service
B (MASONRY WORKS)
Construct 50MM height Kitchen cement mortar base with skirting
Construct 50MM height W/M & Fridge cement mortar base with full tiling
C (PLUMBING WORKS)
Supply & install inlet & outlet piping for Kitchen sink
Supply & install inlet & outlet piping for W/M
Supply labour to install Kitchen sink & tap
Supply labour to install 2 sets instant heater OR storage heater
Supply labour to install 2 sets Bathroom accessories
D (CEILING WORKS)
Design & construct L-box @ Living/Dining
Design & construct false ceiling @ Foyer area
E (CARPENTRY WORKS)
Design & fabricate 20ft (Top & Bottom)Kitchen cabinet using solid plywood with Laminate +
soft closing doors
Supply & install 10ft solid surface worktop
Supply & install designer handles
Supply & install 1 set frosted glass door
Supply & install 1 column of drawer with 1 set cutlerytray
Supply labour to install cooker hood & hob
Design & fabricate 5ft full height wardrobe @ M/Bedroom in Laminate
F (MISCELLANEOUS WORKS)
Painting of internal wall & ceiling using Nippoin paint (Max 4 colors)
Painting of all doors,frames,pipes & gate
Provide corrugated paper protection to flooring
Chemical washing for whole unit
General cleaning upon completion of works
SUB TOTAL AMOUNT FOR PACKAGE : $ 8,188.00
(ADDITIONAL WORKS)
G (HACKING & DISMANTLING WORKS)
(KITCHEN)
1 Supply labour to demolish away half height of entrance L-shape wall $ 550.00
(Subject to HDB approval)(Exclude PE endorsement if required by HDB)
(MASTER BEDROOM)
1 Supply labour to hack away ext'g metal door frame, remove door & hack away side wall $ 280.00
(BEDROOM 2)
1 Supply labour to hack away ext'g metal door frame & remove door $ 250.00
I (MASONRY WORKS)
(KITCHEN)
1 Supply labour & materials to touch up to affected wall tile areas using matching HDB
tiles $ 400.00
2 Supply labour & materials to construct additional 50MM height Kitchen cabinet base $ 200.00
(MASTER BEDROOM)
1 Supply labour & materials to render smooth to ext'g door frame areas $ 200.00
2 Supply labour & materials to construct timber door frame for new entrance $ 290.00
3 Supply labour & materialsto construct door lintol above new door frame $ 180.00
(BEDROOM 2)
1 Supply labour & materialsot seal up ext'g door entrance using 63MM hollow blocks $ 280.00
2 Supply labour & materials to cement plaster smooth to both sides of wall $ 200.00
(MASTER & COMMON BATHROOM)
1 Supply labour & materials to construct shower kerb c/w full tiling $ 280.00
H (PLASTERCEIL WORKS)
(LIVING AREA)
1 Design & construct plaster false ceiling $ 450.00
(DINING AREA)
1 Design & construct plaster false ceiling $ 550.00
2 Design & construct cove light holder $ 250.00
(PASSAGEWAY AREA)
1 Design & construct plaster false ceiling $ 280.00
(MASTER BEDROOM)
2 Design & construct cove light holder $ 350.00
(BEDROOM 2)
I (ELECTRICAL WORKS)
(LIVING)
1 Supply labour & materials to run 8 nos PLC downlight points $ 392.00
2 Supply labour & materials to relocate 1 no SCV point & 1 no 13AMP Double socket into
TV wall $ 250.00
3 Supply labour & materials to run 4 nos light point @ Platform area $ 196.00
(DINING)
1 Supply labour & materials to run 5 nos PLC downlight points $ 245.00
(MASTER BEDROOM)
1 Supply labour & materials to run 4 nos PLC downlight points $ 196.00
2 Supply labour & materials to run 6 nos Cove light points $ 294.00
3 Supply labour & materials to relocate 1 no SCV point & 1 no 13AMP Double socket into
TV wall $ 250.00
4 Supply labour & materials to run 3 nos light point @ Platform area $ 147.00
5 Supply labour & materials to run 2 nos light points @ Bedhead $ 98.00
(BEDROOM 2)
(KITCHEN)
1 Supply labour & materials to relocate 1 no Lighting switch & 1 no 13AMP Double socket $ 250.00
(Entrance wall area after demoltion )
J (CARPENTRY WORKS)
(KITCHEN)
1 Design & fabricate additional 2ftL Kitchen cabinet (Package consist 20ftL) $ 240.00
2 Supply labour & materials to install additional 1ftL solid surface worktop $ 85.00
(Package consist 10ftL)
3 Design & fabricate 2ftL x F/H Storage cabinet using solid plywood in selected high grade
Laminate finished for built-in Oven & Microwave $ 720.00
4 Design & fabricate additional 3.5ftL Bottom Kitchen cabinet using solid plywood in selected
high grade Laminate finished $ 420.00
5 Supply labour & materials to install additional 3.5ftL solid surface worktop $ 298.00
(LIVING AREA)
1 Design & fabricate 7ftL x F/H Design TV feature wall using solid plywood in selected
high grade Laminate finished $ 1,960.00
2 Supply labour & materials to install mechanism for TV rotating $ 280.00
3 Design & fabricate 5ftL x L/H Design TV console using solid plywood in selected high
grade Laminate finished $ 850.00
4 Design & construct elevated Platform using solid plywood $ 1,400.00
(DINING AREA)
1 Design & fabricate 6ftL x L/H Dining sette using solid plywood in selected high grade
Laminate finished $ 1,020.00
2 Design & fabricate 6ftL x 2.5ftH cushion backing @ Sette $ 720.00
(MASTER BEDROOM)
1 Design & construct elevated Platform using solid plywood $ 1,100.00
2 Design & fabricate 7ftL x L/H Bedhead using solid plywood in selected high grade
Laminate finished $ 1,400.00
(BEDROOM 2)
1 Design & fabricate 11.5 ftL x F/H Walk-in wardrobe using solid plywood in selected high
grade Laminate finished for carcass c/w color polygrene internal finished(w/o doors) $ 2,415.00
2 Design & fabricate 10 ftL x F/H Walk-in wardrobe using solid plywood in selected high
grade Laminate finished for carcass c/w color polygrene internal finished(w/o doors) $ 2,100.00
3 Design & fabricate 2.5ftL x L/H wall mount suspended Dresser using solid plywood in
selected high grade Laminate finished $ 400.00
4 Design & fabricate 4ftL x L/H wall mount suspended Study console using solid plywood
in selected high grade Laminate finished $ 640.00
1 Design & fabricate 3ftL x L/H Storage cabinet using solid plywood in selected high grade
Laminate finished @ ext'g Vanity basin(Master Bathroom) $ 480.00
2 Design & fabricate 2.5ftL x L/H wall mount suspended Vainty cabinet using solid plywood
in selected high grade Laminate finished(Common Bathroom) $ 400.00
3 Supply labour & materials to install 2.5ftL solid surface worktop @ Vanity cabinet $ 225.00
K (GLASS WORKS)
(DINING)
1 Supply labour & materials to install 6ftL x 3.5ftH x 5MM thk Tinted wall mirror $ 420.00
1 Supply labour & materials to install F/H Mirror @ Basin area $ 480.00
2 Supply labour & materials to install 10MM thk clear Tempered glass swing door shower
screen @ Master Bathroom $ 650.00
3 Supply labour & materials to install 10MM thk clear Tempered glass sliding door shower
screen @ Common Bathroom (L-shape) $ 700.00
(KITCHEN)
1 Supply labour & materials to install 10MM thk clear Tempered glass fixed panel on entrance
half height wall $ 750.00
2 Supply labour &materials to install 10MM thk clear Tempered glass swing door
(1 swing + 1 fixed) $ 850.00
K (PLUMBING WORKS)
(COMMON BATHROOM)
1 Supply labour to install 1 no new design basin (basins supply by owner) $ 80.00
L (WINDOW WORKS)
1 Supply labour & materials to install aluminium sliding window @ Service Balcony
(BA/NA) $ 650.00
N (LAMINATE FLOORING)
(LIVING AREA)
1 Supply labour & materials to lay heavy duty HDF Laminate floorboard @ Platform area $ 880.00
(MASTER BEDROOM)
1 Supply labour & materials to lay heavy duty HDF Laminate floorboard @ Platform area $ 600.00
M (OTHER WORKS)
1 Debris disposal costs $ 2 50.00
2 HDB permit handling fess $ 150.00
GRAND TOTAL AMOUNT : $ 40,205.00
As i'm building a walk in wardrobe, (Design & fabricate 5ft full height wardrobe @ M/Bedroom in Laminate) will be removed. Is this quote reasonable for a 5 room flat?
