Justin Lim
Looking For Direct Contractors
Hi guys,
I'm just sick and tired of talking to all ID's and reading from the forum, we won't be able to know whether are we fortunate enough that they keep their words or not till start works then all problem arise. Hence, decided to do my home reno myself.
I've got some idea of the design, material and looks that i want which includes cabinet, flooring and false ceiling.
Anyone can recommend some reliable contractor here that can do all this??
Btw, i would need electrician and plumber also for the pipe work.
Fellow forumer pls PM me if you have good recommendation.
Your kindness is deeply appreciated.
We moved into a condo with an open yard / kitchen. The previous owner installed window grilles above the iron bar across the parapet. We decided to remove the iron bar + grilles completely and install casement windows.
Can any kind forumer recommends reliable aluminium casement window installers that will remove the iron bar + grille + install new aluminium casement windows?
Ah, I also need to mention that there's a gap on the top right corner between the top of the grille frame and the ceiling. Meaning the wall to ceiling measurement on the right is slightly longer than the left vertical and as the window grille is in rectangle form, a space is created on the right. Not sure if you guys know what I meant. Thus I need the aluminium casement window installer to be a handy man to be able to use cement to level the ceiling height.
Thanks in advance for recommendations.
