kooky
K's Home
  On 3/20/2013 at 7:45 AM, kooky said:
The officer in charge responded to the email I wrote him to clarify if I can remove the horizontal metal section, he said it is part of the architecture features of the building that must be retained. Bummer!
Ya that's what my ID told us. He said some inexperienced ID duno and removed it. He told us die die cannot remove though it can be an eye sore. I have seen some EM owners hang their laundry pole with support of that metal bar.
Edited by spikedoll
The husband and I decided to hop over to the flat to check it out. When I arrived it was almost 7:00pm. There are some (not much) progress and quickly I took out the camera-phone and took a few pictures before the sky turns dark.
Pipes have been boxed up.
1st floor bathroom
Pic 1 - exposed pipes in the common bathroom on 2nd floor
Pic 2 - Pipes have been boxed up
Edited by kooky
  On 3/22/2013 at 12:39 PM, kooky said:
Bathtub in MBR is installed
Passer-by can't look through the unit when windows along the corridor are closed
Nice bathtub you have :dribble: :dribble: ...thinking of getting e same as well...wondering how much will it cost for the whole installation?? :)
Thank you!
The bathtub is cheap, just cost $500.
Cost of bath & shower mixer = $195
Cost of Shower set/rail +hose = $550
Supply labour & raw material to construct bathtub support $400
Cost for labour to install the bathtub as well as the rain shower = $450.
Edited by kooky
Thank you! :-)
We will install grilles, hence we have decided to leave the blinds out.
  On 3/28/2013 at 9:44 AM, spikedoll said:
Hey I like your windows! No need install blinds !
Trunking of the aircon pipes have been done. Pictures below are taken this morning.
The trunking is done in the guest's room and behind this wall is my daughter's room
The connection made from the guest's room to my daughter's room. This big 'lobang' will be patched up.....of course :-)
This is how the trunking is done in the master bedroom.
The trucking done in the hallway that connects to all the 3 bedrooms. Pic 1
Pic 2
Edited by kooky
U-channel and treads on the first flight of stairs are up. Treads need sanding, polishing and varnishing before it is completely done up.
View of the staircase from the hallway on 2nd floor.
Edited by kooky
We went to select lights. Chandelier is not in our shopping list since we have decided to install ceiling fans in the entire flat. We just chose simple light fitting so long it does the job. But due to the fact that there are lots of ceiling lights, we ended up buying over 40 light-fitting, with mix of PLC and LED lights. The cost is more than we thought it would be.
  On 3/28/2013 at 12:26 PM, kooky said:
Thank you!
2k++ for the total installation :dribble: :dribble: :dribble: :dribble:
Met up with the contractor this afternoon to discuss on some carpentry works before the carpenter starts working on the kitchen, wardrobes and shoes cabinet.We have purchase lights since only last week and the 1st coat of painting was done only on Monday, we then decided to change some laminates now as things are shaping up
Initially, the husband does not want to plaster the wall but after discussion with the contractor, for aesthetic reason, he decided to plaster up the entire unit and in fact, it does look better than rock stone wall effect.
I will be replacing some of the images of laminates which we had selected earlier to keep this T-blog updated.
Edited by kooky
The light in the 2nd picture is nice! How much did you pay for it? Is it LED?
