stupified
Mbr Reno Ideas Advice
We are thinking of renovating our master bedroom, but due to the position of the windows and door, we are not sure how to get/place the furniture.
we are looking at placing our king size bed with bedframe and a wardrobe and a small bed side table. the wardrobe has not been decided. no TV or other tables in the room.
See floor plan below/attached.
So far, we have to follow the previous arrangement of the wardrobe and bed. which is the same as the above attached floor plan
we are thinking of a few more arrangements.
L shaped Wardrobe
Any ideas would be appreciated!
i would have hacked the connecting wall between the rooms. then build two wardrobes, back to back to each other.
i did this to my corridor. my id proposed to hack the wall (connecting to Master), and build a wardrobe.
it is back to back with the wardrobe in master.
I also did the hacking of wall between two walls for my current flat. it save quite some space. but in your case you will have to change the positioning of your bed.
http://postimage.org/image/l7lulr6ud/
Dear Sir,
I took your layout and plan a bit for your reference.
You might want to consider this as what i feel that it helps to free up spaces.
It is not too advisable to cut up small space as it will feel very cluttered.
You can contact me at ***@yahoo.com.sg for any doubts you wish to clarify
Gilbert
Edited by gilbertyang
