taitaineo 1 Report post Posted January 5, 2013 My bathroom glass has accumulated much water stain (visible when dry) over time. I tried various methods but failed to remove it.Can anyone kindly advise the effective method to remove these stain or advise any service provider offers the cleaning services?Thank you. Share this post Link to post Share on other sites
dexterou 0 Report post Posted January 27, 2013 did you try using vinegar to clean? Share this post Link to post Share on other sites
taitaineo 1 Report post Posted January 29, 2013 Thank you for responding.I had tried using vinegar with baking soda.It does not work. Hope anyone here can offer a solution.did you try using vinegar to clean? Share this post Link to post Share on other sites
yoongf 11 Report post Posted January 29, 2013 Any bathroom cleaning product that says soap scum remover.Need to spray and let it soak a few minutes, then scrub off.Cleaning this is never an issue leh. If like din clean for a few years. need to keep repeating. Alternatively.. use a scrapper tool? Share this post Link to post Share on other sites
bee7386 0 Report post Posted January 30, 2013 "JIF " should be ok Share this post Link to post Share on other sites
artblakey 0 Report post Posted January 31, 2013 Yeah. Jif (or any similar cream cleaner) has worked for me. Can also try using a melamine sponge (aka 'magic sponge').More tips:http://www.apartmenttherapy.com/how-to-clean-so-137401 Share this post Link to post Share on other sites
Colombian 62 Report post Posted February 1, 2013 Yeah. Jif (or any similar cream cleaner) has worked for me. Can also try using a melamine sponge (aka 'magic sponge').More tips:http://www.apartmenttherapy.com/how-to-clean-so-137401I tried JIF before, simply does not work at all, infact problem became worse.I also have the same problem as taitaineo and have run out of solutions, anyone has any suggestions? Share this post Link to post Share on other sites
bepgof 20 Report post Posted February 1, 2013 My bathroom glass has accumulated much water stain (visible when dry) over time. I tried various methods but failed to remove it.Can anyone kindly advise the effective method to remove these stain or advise any service provider offers the cleaning services?Thank you.When wet, clean with used news paper. After sometimes, stains will be gone.He who wash car should know this. Share this post Link to post Share on other sites
Colombian 62 Report post Posted February 3, 2013 (edited) You can use something called HCL89 from http://hcl89.byethost10.com or http://hcl89.atwebpages.com so far for me this is the only solution i see that works. Although its a tile cleaner, it workds for glass surfaces as wellHope this helps you out Thanks for the recommendation will try the HCL 69 thing and will repost here soon to letyou guys know how it worked out for meThanks Edited May 21, 2013 by Colombian Share this post Link to post Share on other sites
fierydragon 1 Report post Posted February 12, 2013 I use diluted acid and a hard sponge. It works, but repeats after a month or so. Leaving the glass door open to dry does help. Share this post Link to post Share on other sites
newman 0 Report post Posted February 12, 2013 Have you tried WD40 on the stains...?It might help... Share this post Link to post Share on other sites
taitaineo 1 Report post Posted February 13, 2013 Hi, may I know where should I get the acid? Does it damage the marble floor?I use diluted acid and a hard sponge. It works, but repeats after a month or so. Leaving the glass door open to dry does help. Share this post Link to post Share on other sites
taitaineo 1 Report post Posted February 13, 2013 Thank you. I tried using WD40 but it didn't work.Have you tried WD40 on the stains...?It might help... Share this post Link to post Share on other sites
eaglef18 1 Report post Posted February 14, 2013 Thank you. I tried using WD40 but it didn't work.Looks like you may have some stubborn whitish stain. Maybe you can try using car's hard wax for the 1st time. I did this on my shower screen doors the last time and it worked for me. Afterwhich, I only need to use the magin sponge to wash them away. Share this post Link to post Share on other sites
taitaineo 1 Report post Posted February 15, 2013 Thank you for reply. Kindly advise which product of wax (i.e. product name and where you got it) that you used?Looks like you may have some stubborn whitish stain. Maybe you can try using car's hard wax for the 1st time. I did this on my shower screen doors the last time and it worked for me. Afterwhich, I only need to use the magin sponge to wash them away. Share this post Link to post Share on other sites
