taitaineo
Advice On Removal Of White Water Stain On Bathroom Glass
My bathroom glass has accumulated much water stain (visible when dry) over time. I tried various methods but failed to remove it.
Can anyone kindly advise the effective method to remove these stain or advise any service provider offers the cleaning services?
Thank you.
Thank you for responding.
I had tried using vinegar with baking soda.
It does not work. :unsure:
Hope anyone here can offer a solution.
did you try using vinegar to clean?
Any bathroom cleaning product that says soap scum remover.
Need to spray and let it soak a few minutes, then scrub off.
Cleaning this is never an issue leh.
If like din clean for a few years. need to keep repeating. Alternatively.. use a scrapper tool?
Yeah. Jif (or any similar cream cleaner) has worked for me. Can also try using a melamine sponge (aka 'magic sponge').
More tips:
http://www.apartmenttherapy.com/how-to-clean-so-137401
I tried JIF before, simply does not work at all, infact problem became worse.
I also have the same problem as taitaineo and have run out of solutions, anyone has any suggestions?
Thank you.
When wet, clean with used news paper. After sometimes, stains will be gone.
He who wash car should know this.
You can use something called HCL89 from http://hcl89.byethost10.com or http://hcl89.atwebpages.com so far for me this is the only solution i see that works. Although its a tile cleaner, it workds for glass surfaces as well
Thanks for the recommendation will try the HCL 69 thing and will repost here soon to let
you guys know how it worked out for me
Edited by Colombian
Hi, may I know where should I get the acid? Does it damage the marble floor?
I use diluted acid and a hard sponge. It works, but repeats after a month or so.
Leaving the glass door open to dry does help.
Thank you. I tried using WD40 but it didn't work.
Looks like you may have some stubborn whitish stain. Maybe you can try using car's hard wax for the 1st time. I did this on my shower screen doors the last time and it worked for me. Afterwhich, I only need to use the magin sponge to wash them away.
Thank you for reply. Kindly advise which product of wax (i.e. product name and where you got it) that you used?
