mantaone 0 Report post Posted December 9, 2015 (edited) Hi, I would like to check is the HCL effective in removing as i am trying to clean my 10 year old white ceramic tiles + darkened groutAny one can help, any photosThis is due to mould. You can use something called HCL89 to remove it, it willremove the mould as well as well as any stains.You can get it from http://hcl89.byethost10.com or http://hcl89.atwebpages.comTake care Edited December 9, 2015 by mantaone Share this post Link to post Share on other sites
BenBernanke 117 Report post Posted May 17, 2016 On 30/09/2015 at 4:43 AM, BelindaSeah said: I think (if i am not wrong) should be too much moisture Too much moisture can cause tiles to be dirty much faster than usual? 6 Share this post Link to post Share on other sites
GermaineS 45 Report post Posted September 1, 2016 On 18/05/2016 at 6:00 AM, BenBernanke said: Too much moisture can cause tiles to be dirty much faster than usual? I noticed that too especially if you have homogeneous tiles 6 Share this post Link to post Share on other sites
Ella Lim 0 Report post Posted October 10, 2016 Hey guys. I have a solution for your problems. Personally tried and tested this product for myself. Its purely organic, no chemicals and child-safe. Its really cheap too as it is sold in concentrate form.. I've tried to remove stains between tiles, toilet ceiling and along the walls. As simple as spray and leave on for 10minutes, then wipe off with a cloth. You don't even have to rub it hard or scrub.. You can use it for other stuff as well like mopping floor, cleaning grease off kitchen stove, wipe tables, etc. How it works in layman terms is that it uses 'good bacteria' to eat the 'bad bacteria'. Spraying it upon a surface lets the good bacteria spread across the area and it will cling onto the bad bacteria. Even after wiping off the cleaner, good bacteria will continue to cling onto the surface so that it continues to protect the surface from bad bacteria build up even after you've cleaned the surface already. It's just $22 for 1 litre and if you use it daily for cleaning it can last an estimated 1 month. Thus, its really affordable. PM me for more information on the product (VRM Mikroclean) and how to get it. Its not readily available everywhere as its relatively new to Singapore's market. Share this post Link to post Share on other sites
CandiceChua 45 Report post Posted November 15, 2016 (edited) On 09/12/2015 at 4:54 PM, mantaone said: would like to check is the HCL effective in removing as i am trying to clean my 10 year old white ceramic tiles + darkened grout Had used the http://hcl89.byethost10.com before to clean some of my toilet tiles as well as the grouts and so far the grouts have reverted to the original colour when i first bought the tiles. Very good product if you want to refurbish your grouts or tiles Edited November 16, 2016 by CandiceChua 10 Share this post Link to post Share on other sites
neomatrix 3 Report post Posted November 17, 2016 definitely mould, have improve? Share this post Link to post Share on other sites
HockSeng 96 Report post Posted March 10, 2017 On 18/05/2016 at 6:00 AM, BenBernanke said: Too much moisture can cause tiles to be dirty much faster than usual? I think also depends on the types of tiles, like for example marble tend to get dirty much easier, but i do think moisture and maybe humidity does play a part on how we need to maintain our tiles 1 Share this post Link to post Share on other sites
MikeLim 27 Report post Posted November 30, 2017 On 9/2/2016 at 6:18 AM, GermaineS said: I noticed that too especially if you have homogeneous tiles Homogeneous tiles are like that they look very nice but have to be maintained 5 Share this post Link to post Share on other sites
LauChek 19 Report post Posted November 28, 2019 On 11/17/2016 at 5:55 PM, neomatrix said: definitely mould Mould are always the worst because they always keep coming back and you have to make sure to kill all the mould spores so that mould never comes back on your tiles or walls 4 Share this post Link to post Share on other sites
