wishxpress 0 Report post Posted October 30, 2012 Hi ,Anyone can help with programming Samsung 5230 Digital LockMine can register and open when i manual lock from inside but it does not auto bolt when closed.Is there a need to activate the Auto Bolt function?Help Appreciated...Getting a headache trying to get it to workCheers Share this post Link to post Share on other sites
lobo76 0 Report post Posted October 31, 2012 Sorry, couldn't answer you. But would like to check on how you bought your lock? Is it from Interlock or mydigtiallock, or from ebay, etc and got a locksmith to install?If it is the latter, can you pm me the locksmith contact? Thanks! Share this post Link to post Share on other sites
wishxpress 0 Report post Posted October 31, 2012 On 10/31/2012 at 10:37 AM, mydigitallock said: You may contact me if your lock break out and need locksmith services. Breaking the lock without warranty for rim lock would be $180 for non peak hour and $280 for peak hour.My lock is working but does not auto bolt when I close. Manually turn bolt and use finger can open but the **** thing don't auto lock when I close the door.Can u do programming? Share this post Link to post Share on other sites
wishxpress 0 Report post Posted October 31, 2012 On 10/31/2012 at 7:52 AM, lobo76 said: Sorry, couldn't answer you. But would like to check on how you bought your lock? Is it from Interlock or mydigtiallock, or from ebay, etc and got a locksmith to install?If it is the latter, can you pm me the locksmith contact? Thanks!I installed it myself Share this post Link to post Share on other sites
RooRoo 0 Report post Posted October 31, 2012 I dont have the same exact model but no harm trying...Did u install the magnetic sensor? U'll need that for the auto door lock feature to work.Assuming u have installed it properly, press registration button followed by '4' followed by '*' to toggle auto door lock on/off.Hope it helps. On 10/31/2012 at 1:42 PM, wishxpress said: I installed it myself Share this post Link to post Share on other sites
wishxpress 0 Report post Posted November 1, 2012 Thanks to all for your feedback...I managed to get it to work the bottom lactch needed to be recessed in order to activate the Bolt.Cheers Share this post Link to post Share on other sites
