DancingInTheRain 0 Report post Posted September 6, 2012 Hi! I've a false wall built in my toilet shower area with compartments to put the soap, shampoo and stuff. I notice that my contractor used pky wood and cement to build this. He mentioned that after the cement are put up and then tiled, the wall is good for use. Is this the way to build this false wall? Anyone can pls advise? Thank you! Share this post Link to post Share on other sites
yoongf 11 Report post Posted September 6, 2012 Plywood is 100% wrong. Share this post Link to post Share on other sites
Tiler Seng 57 Report post Posted September 6, 2012 Plywood is 100% wrong.Totally agreed with you yoongf.Beside that, there are 100 other materials that can use it right. Share this post Link to post Share on other sites
mikeyong500 4 Report post Posted September 7, 2012 Hi! I've a false wall built in my toilet shower area with compartments to put the soap, shampoo and stuff. I notice that my contractor used pky wood and cement to build this. He mentioned that after the cement are put up and then tiled, the wall is good for use. Is this the way to build this false wall? Anyone can pls advise? Thank you!Plywood in the toilet showers ? Doesn't seem right... cuz plywood can't last long in places full of moisture.False walls in toilet are usually done using hollow blocks (what my contractors do lol), as for the compartments can actually use glass panels to act as shelves. But as Seng said, there are many other materials that can be used too.Hope this helps. ,Mike Share this post Link to post Share on other sites
DancingInTheRain 0 Report post Posted September 9, 2012 Sigh... I asked my contractor and he said that ply wood then cement over, confirm no problem. Then I went to knock... Hollow de! The compartments for the shampoo and studf is done usig a thick block of wood... ;p Hollow blocks also give hollow sound? Sorry for the noob question. Hahhaaa.... Share this post Link to post Share on other sites
Minerat 1 Report post Posted September 9, 2012 Hollow blocks are pretty soild when cemented over. Definitely no hollow sound. I guessed the plywood should be okay ba after cement and tiling. If moisture still can get in after that, then workmanship must be pretty lousy liao. Share this post Link to post Share on other sites
DancingInTheRain 0 Report post Posted September 12, 2012 Hmm... Checked again, he said the walls are using cement sheets. Only the 2 supports for compartments in the wall are solid wood (abt an inch think). The wall is then tiled. When I knock on it, it's produces a hollow sound, which I don't like. Those 2 pieces of wood also cause me concern. He says it's better than hollow block as if any problems with the pipes, just tear out part of the wall. But I'm thinking, if need to tear out, might as well tear out the whole thing else difficult to align the tiles anyway... And how often do we get problems with water pipes??? Is my rationale correct or Shd I just follow what he says? Share this post Link to post Share on other sites
yoongf 11 Report post Posted September 12, 2012 Nobody uses wood in toilet. Other countries.. humidity low.. can, Sg no way.So many condo.. all tiled with marble walls in toilets.Minimally is hollow block. wood and cement board.. got different expansion rate, and is also different from the tiles. Will crack very soon. Share this post Link to post Share on other sites
Tiler Seng 57 Report post Posted September 12, 2012 Hmm... Checked again, he said the walls are using cement sheets. Only the 2 supports for compartments in the wall are solid wood (abt an inch think). The wall is then tiled. When I knock on it, it's produces a hollow sound, which I don't like. Those 2 pieces of wood also cause me concern. He says it's better than hollow block as if any problems with the pipes, just tear out part of the wall. But I'm thinking, if need to tear out, might as well tear out the whole thing else difficult to align the tiles anyway... And how often do we get problems with water pipes??? Is my rationale correct or Shd I just follow what he says?if he is using water resistant board then is fine. Share this post Link to post Share on other sites
DancingInTheRain 0 Report post Posted September 12, 2012 Thanks for your replies, Yoongf and Tiler Seng! Share this post Link to post Share on other sites
yoongf 11 Report post Posted September 13, 2012 if he is using water resistant board then is fine.From a moisture resistent point of view, yes, it is ok. But owner don't like the hollow sound. I just don't see the reason why hollow block is not being used.This is not a feature wall where nobody touches it regularly. This wall is highly utilised in a hostile environment, and has compartments for shampoo bottles. Share this post Link to post Share on other sites
Tiler Seng 57 Report post Posted September 13, 2012 From a moisture resistent point of view, yes, it is ok. But owner don't like the hollow sound. I just don't see the reason why hollow block is not being used.This is not a feature wall where nobody touches it regularly. This wall is highly utilised in a hostile environment, and has compartments for shampoo bottles.Huh?btw, i have came across HDB rejected layed of hollow block for these compartment wall due to weight load, they then permitted me by changing it to light weight block. Share this post Link to post Share on other sites
shanks 0 Report post Posted September 18, 2012 What happened to mine was the guy who did my false ceiling and L-box came and do the pipe box-up in all my toilet and shower. So with brackets and aluminum/stainless steel sheets, he boxed them up and screw the same sort of wood they used in the false ceiling. The tiler then put a layer of water proofing cement (the same sort they use on the kitchen and bathroom floors) before tiling it. Share this post Link to post Share on other sites
Lauer 15 Report post Posted September 19, 2012 What happened to mine was the guy who did my false ceiling and L-box came and do the pipe box-up in all my toilet and shower. So with brackets and aluminum/stainless steel sheets, he boxed them up and screw the same sort of wood they used in the false ceiling. The tiler then put a layer of water proofing cement (the same sort they use on the kitchen and bathroom floors) before tiling it.Oh oh...Not for the shower cubicle area, I hope.http://www.youtube.com/watch?v=C1KtScrqtbc&feature=youtube_gdata_playerEnjoy! Share this post Link to post Share on other sites
Tiler Seng 57 Report post Posted September 21, 2012 there this is an example of my common toilet. my board i think is not gypsum board but more like made of hard ceramic. when u knock is like steel sound.its Calcium Seilicate Board Share this post Link to post Share on other sites
