versionv 0 Report post Posted August 27, 2012 Hi crypaz I m also from the same neighborhood. Would like to check how you do up your balcony . I intend to lay timber strip but the cost is quite high. Btw I also installing the same range of supreme flooring but not yet confirm which colour to choose. I like the finishing because of the groove which make it looks like natural timber flooring. Share this post Link to post Share on other sites
crypaz 1 Report post Posted August 27, 2012 (edited) On 8/27/2012 at 9:01 AM, versionv said: Hi crypaz I m also from the same neighborhood. Would like to check how you do up your balcony . I intend to lay timber strip but the cost is quite high. Btw I also installing the same range of supreme flooring but not yet confirm which colour to choose. I like the finishing because of the groove which make it looks like natural timber flooring.Hi, I done tiles for my balcony. You can refer to earlier pictures.Now I'm thinking if I should have done timber strip since my whole house flooring is woodenInitially didn't have this idea cause thought the balcony is too small wouldn't look nice with the timber stripHave you check out the cost for timber strip? Our balcony is very small.You plan to do laminate flooring for the whole house including the living room? Edited August 27, 2012 by crypaz Share this post Link to post Share on other sites
versionv 0 Report post Posted August 27, 2012 I was quoted above$1k just for that small little balcony. I still seraching for cheaper offer otherwise will go for tiling instead. Yes,my whole house will be in laminate except Mbr I am considering carpet since there is not much difference in price. Share this post Link to post Share on other sites
ongcs 3 Report post Posted August 27, 2012 Welcome to punggol, just wondering whether you had used homo tiles for your balcony, it can be slippery during rainy day. Share this post Link to post Share on other sites
crypaz 1 Report post Posted August 27, 2012 (edited) On 8/27/2012 at 10:55 AM, versionv said: I was quoted above$1k just for that small little balcony. I still seraching for cheaper offer otherwise will go for tiling instead. Yes,my whole house will be in laminate except Mbr I am considering carpet since there is not much difference in price.my balcony i use homogeneous tiles it's about $450 for tiles and workmanship to lay the tiles.Unless you want to use the outdoor floor decking from Ikea?http://www.ikea.com/sg/en/catalog/products/60174219/Carpet for MBR? You mean just carpet on top of the cement screed? Edited August 27, 2012 by crypaz Share this post Link to post Share on other sites
crypaz 1 Report post Posted August 27, 2012 On 8/27/2012 at 1:43 PM, ongcs said: Welcome to punggol, just wondering whether you had used homo tiles for your balcony, it can be slippery during rainy day.Yup using homogeneous tiles... thought it would be easier to clean ... Share this post Link to post Share on other sites
ongcs 3 Report post Posted August 27, 2012 On 8/27/2012 at 2:14 PM, crypaz said: Yup using homogeneous tiles... thought it would be easier to clean ...Yup, it should be, run a test, pour water on them and try out whether slippery anot? It can be dangerous on my view. Share this post Link to post Share on other sites
crypaz 1 Report post Posted August 27, 2012 On 8/27/2012 at 2:18 PM, ongcs said: Yup, it should be, run a test, pour water on them and try out whether slippery anot? It can be dangerous on my view.Opps...to clarify I got those tiles that's a bit rough surface so maybe it's ceremic instead of homogeneous...hopefully wouldn't be that slippery...but still...thanks for highlighting...by the way, which part of punggol u from? Share this post Link to post Share on other sites
ben107 0 Report post Posted August 27, 2012 Hi Crypaz, can I check if there are any recess areas in the mbr? Share this post Link to post Share on other sites
ongcs 3 Report post Posted August 27, 2012 On 8/27/2012 at 2:26 PM, crypaz said: Opps...to clarify I got those tiles that's a bit rough surface so maybe it's ceremic instead of homogeneous...hopefully wouldn't be that slippery...but still...thanks for highlighting...by the way, which part of punggol u from?If ceramic, the 4 line corners are rounded downward, homogenous line corners are 90 degree angled. Homogenous can be rough too, for outdoor purposes, just be safe cheers! I'm from Sapphire Share this post Link to post Share on other sites
Sygnur 0 Report post Posted August 27, 2012 Ur reno is coming up well. Can i check with u if ur sink is topmount? Share this post Link to post Share on other sites
crypaz 1 Report post Posted August 27, 2012 On 8/27/2012 at 2:39 PM, ben107 said: Hi Crypaz, can I check if there are any recess areas in the mbr?You referring to after they lay the laminate flooring ? Share this post Link to post Share on other sites
crypaz 1 Report post Posted August 27, 2012 On 8/27/2012 at 2:39 PM, ongcs said: If ceramic, the 4 line corners are rounded downward, homogenous line corners are 90 degree angled. Homogenous can be rough too, for outdoor purposes, just be safe cheers! I'm from Sapphire Okay then mine should be homogeneous tiles base on your description as it's 90 degree angled. Thought for outdoor it's better to choose a rough surface . Share this post Link to post Share on other sites
crypaz 1 Report post Posted August 27, 2012 On 8/27/2012 at 2:43 PM, Sygnur said: Ur reno is coming up well. Can i check with u if ur sink is topmount?Most likely doing.bottom mount Share this post Link to post Share on other sites
ben107 0 Report post Posted August 27, 2012 On 8/27/2012 at 2:48 PM, crypaz said: You referring to after they lay the laminate flooring ?Coz from your photos, i dont see any recess areas.. Thought you might have boxed them up.. Share this post Link to post Share on other sites
