crypaz
Home @ Punggol
Nope doesn't affect the kitchen cabinet.
I think i paid about 400 plus including the tiles to do this cement wall. Actually the tiles only need to cover the inner side but the tiler also cover the outer side which actually will be covered by the carpentry.
Thanks for the info. I think the tiler is right considering if want to prevent wood from damage if water leakage.
From the pic, the tiler did left, right, inner side wall, with tiles. The closing cabinet door remains as wood.
Wah! Too expensive for me... Sad.
Btw, is it water resistant?
Yes it's water resistant...the cost depends on your door size...for mine the size is bigger than usual cause it's cater for handicap..i guess for your flat @holland it's older flats the door size is smaller...as compared to wooden lourve door the pricing is at least lower...as it's swing slide so will not "eat" up my toliet space...
but you need to have shower screen for this type of door cause the water will splash out...
Edited by crypaz
Thks for the info!
Yup, i will be installing shower curtain to prevent water from splashing out.
Mine quote 500+>..
HI crypaz,
thats great, can you PM me your contractor contact becos my contractor for some reason refuse to paint my bedroom doors white, he got all kinds of reason for not doing it. I intend to paint my doors white after my reno is done, so its a small job. thanks!
Yes it's white...
HI crypaz,
My doors i got them from ****, so it's actually the workers from **** that paint my door white...not my contractor....
Carpentry uncle came up to do additional shelving for the kitchen bottom cabinet, done up the MBR mirror, and install the top shelf for the kitchen cabinet
Mop and broom holder. Makes the place neater.
Painting touch up is done. Suppose to paint door frame but due to time constraint it was push to next sat. Installation of tap is done. Gas supply is ready. Chemical washing is only half done....:-(
Furniture will come in next sat.
Edited by crypaz
