csjdraj 0 Report post Posted August 3, 2012 hi guys,Just got a quote from my contractor.You guys might want to give me feedback on it.ThanksDismantling Works Dismantle existing sanitary @ master bathroom 1 set $80Dismantle existing sanitary @ common bathroom 1 set $80Dismantle existing kitchen cabinet $250Hack both toilet wall tiles @ master and common bathroom. $850Hack away existing R/C kitchen sink/stove $280Masonry work Supply and Overlay Wall Tiles @ master bathroom ("Anti-Stain" Heavy Ceramic Wall Tiles, 450 x 300 mm; and (tiles not more than $2.60/sq ft) $1080Supply and Overlay Wall Tiles @ common bathroom("Anti-Stain" Heavy Ceramic Wall Tiles, 450 x 300 mm; and (tiles not more than $2.60/sq ft) $1080Supply labour to uplift sand, cement & materials to unit (Haulage Loading) $750Supply & construct kitchen sink with R/C slab built-in $500Supply & construct vanity basin with R/C slab(wall to wall) including hard solid surface $800work topDoor Works Supply & install nyatoh main door c/w lock set & magnetic stopper (twin door ) 1No $950Supply & install flat nyatoh veneer doors c/w lever lock set & magnetic stopper 3No $890Supply & install 1 set slim cabinet at common toilet(L3ft. X H3ft. ) $180Plumbing Works Change both bathrooms cold water piping to new stainless steel pipe $600Connect inlet & outlet piping for wash basin $100Connect inlet & outlet piping for kitchen sink $80Supply labour to install basin & pedestal WC @ master bathroom $145Supply labour to install accessories @ master bathroom $30Supply labour to install basin & pedestal WC @ common bathroom $145Supply labour to install accessories @ common bathroom $30Supply labour to install instant heaters $40Supply labour to install kitchen sink, hob & hood $80Miscellaneous Supply & lay protection sheet $100Clean up whole unit with chemical washing $180Clearing off debris $180Whole House Painting including toilet and kitchen (ceiling standard white/wall 4 colour) $1150Kitchen AreaDesign & fabricate top & bottom kitchen cabinet in laminate finish c/w 04 sides ABS trimmingswing doors, choices of drawers, cutlery tray, 02 pcs of glass panels & designer handles(Length includes + top cabinet + bottom cabinet 33ft) $34651 set top and base kitchen cabinet c/w laminate finish at the other side (6.5 ft. ) $682Supply & install stainless steel dish rack with hydraulic system & glass panel $120Supply & install solid surface worktop for kitchen cabinet(including sink area)(15ft. ) $900Supply & install soft closing hinges FOCDrawer runner use soft closing mechanism @ $35 $140Supply and use internal panel with woody colour board PVC at bottom kitchen cabinet $500only additional chargeSupply and install 2 piece 900mm width colour tempted glass wall backing at kitchen $450Sink and stove areaSupply and install 2 set aluminium grill (fixed panel) at 2 toilet existing window $260Grand total $17147 Share this post Link to post Share on other sites
mikeyong500 4 Report post Posted August 7, 2012 Reasonable. For cabinets dun think they are using blum soft closing, juz normal ones which might not be as effective. Do take note. Oh and the Countertop they using is juz normal solid surface at $60pfr. The rest are okays juz that haulage abit ex... but plus minus here and there okays la... Share this post Link to post Share on other sites
HK8255 0 Report post Posted August 23, 2012 Not a bad one...quite ok. Share this post Link to post Share on other sites
