WeikiRee
Bosch Induction Pmi968Ms - What Amp?
Any members can confirm for Bosch Induction Hob model PMI968MS - what is the amp plug requirement?
Went to 3 different places all gave me different answers since it was not stated in catalogue.
Harvey Norman - can connect to 15amp but performance will be affected
Gain City - need 30 amp plug
Best Denki - normal 13amp plug is sufficient
Pls help ... Thanks to all in advance.
try pm terry 87 he the bosch person to go to
Edited by dodofish
- Front left: 2.2kW with booster 3.3kW (Ø210mm)
- Front right: 1.4kW with booster 1.8kW (Ø150mm)
Normal 2.2kW + 1.4kW = 3.6kW (3600 / 220) = 16Amps
With Boost 3.3kW+1.8kW = 5.1kW (5100/220) = 23Amps
So if u use 15 amp it will work for normal usage but if u use boost then it will trip
if Old HDB with then not advisable other than only use one side ...
Thats what i understand... Hope this helps...
