tealover
Partition Between Main Door & Living
Thinking of putting a partition between the main door & the living room ( to create more privacy so that ppl will not able to look inside when the main door is open). Anyone has done that can pls share the photo with me?
  • Like 2
never done this myself but have you thought of using a chinese screen? like this
just a reminder folding screen might be a little risky if there is small children at home... it may trap their little fingers or fall or them... I have seen some build in cabinet with glass display that acts as partition. Mayb you can check with you ID.
Edited by nyssa
Have a look at my Reno t-chat blog. I think that is the partition u are looking for right ? Note: my Reno is still wip.
If you don't mind, can try using a full height shoe cabinet as a partition.
Can see the sample from my 3D drawing here.
Hope this helps :)
Hope this helps :)
Look like a good idea. i am thinking of doing it but will it make the living room smaller. mine is a 3 room flat
Hi Woods72, i'm not so sure for 3room. Prob run the idea through with your ID / contractor and let them comment on the practicality? i.e., will there be enough space for dining area..
