stan79
Air-Con Help
This is my first time buying aircon for my new HDB flat. I got this quote from KxxSxxx for Mitsubishi Electric System 4 Inverter for 3 bedroom + 1 mini study room.
1) Compressor MXY4A28VA (28,000 btu)
2) Fancoil MSYGE10VA x 4 (9,000 btu)
3) 1/2" Insulflex class 1 insulation
4) 23 SWG copper piping
5) 16mm drainage piping
Warranty: 5 yrs workmanship, 5 yrs compressor & 1 yr spare parts
Total damage: $3,360 nett
Is the quote ok? I think Armaflex insulation is more popular. Anybody uses Insulflex before? Should I upgrade to class 0 insulation instead? Think class 1 or 0 is referring to the fire rating of the insulation right?
I feel the quote is quite reasonable. They have one of the best price for ME and MHI. I also took MHI Sys 3 from them. Installing soon. Hoping everything will go well.
As for insulation, I upgraded mine to Armaflex with extra $$. Reason is because my piping will be hidden behind my cupboard so have to use Armaflex as it has better absorption. Do not worried on the insulation as during the site survey, they will tell you which insulation is best for your situation. As for the class, I believe class 1 should be enough. You should not spend the money to upgrade to class 0 and it is not worth. You should spend that money to upgrade to Armaflex instead rather than the class.
Hope my advice helps! Cheers!
Edited by unity58
