louisxii
Hdb Water Valve Missing
Hi today was thinking to change the water pipe but was unable to locate the main water valve in order to switch off the water supply. I opened up the room with a tag on top "water/Gas" in front of my unit and only saw 2 pipes inside the room with no meter and valve. The other "electric" room can see electric meter inside n some main circuit breaker.Any one know where is the valve?
The water valve is in there all you need is a key to turn off the main water supply :yamseng:
