Tigaroo
My Humble Home.....
Hi!
Water resistant will be the correct word to use la. Most laminated flooring consists of 4 layers. The top most layer is called the wear layer. This layer yes, is water proof and wear resistant. The reason why I say water resistant is a better word to use is because the joint area between the laminated flooring is not water proof. If there is water spillage on the joint area, the water will seep through into the laminate if the spillage is not wiped off immediately:)
There is also moisture in the air as well, that is why the vapor barrier is a must to make the laminated flooring last longer. So installation must be done the proper way.
Hahaz :thumbs up:
Cheers :yamseng: ,
Mike
.... thats why i am still contemplating between.... the laminate wood floor- water resistant vs the Laminate vinyl floor water proof ....
Day 6- Tuesday... went to check out in the evening.
Plaster work continue.....
Aircon Changed....
Hall- 18k BTU
MBR- 12k BTU
Study- 9k BTU
left over materials....
Also. Kitchen glass door rail fixed
Edited by Tigaroo
Should The glass dividing door between Hall and Kitchen be clear glass or frosted??
Maybe u can make a design on your glass then get the glass maker sandblast the pattern or design out for you
Eg; you and your wife name :sport-smiley-004:
I prefer clear glass, makes the interior more spacious. Unless you want privacy.
Agree too.... only worry is scare guest might walk into the glass door.... :jawdrop:
add some frosted line will help??? :unsure: or first the top part??
hm..... pattern.... lines???
no la... names... names on wall or glass door sounds old fashion :D
The glass door is too prevent the aircon leaking into kitchen... so i guess most of the time it will be open
Edited by Tigaroo
What is chemical wash/ acid wash????
Can you wash those stain/ mould in the bath room??
Mould shld be able to removed by most bleach for floor
Bro your reno look swee :dancingqueen:
Cos the previous owner.... really no maintenance and take care... not even scrub his bath room..... so on the Slate tiles on bath room wall has those stain...( purple/ brown color)???
Heyz,
No worries about the clear glass panel. It is actually quite obvious and there is a mini handle too for you to slide but still making a pattern definitely to make it more prominent. cost more lo. Sandblast quite expensive... or try frosted glass film???
And you mean most of the time the kitchen will be 'closed' right? to prevent aircon leakage from living?
Just ask your ID/contractor acid wash whole house ba. Should be able to remove the mould and stains.
Cheers,
Mike
Cheers,
Mike
Edited by mikeyong500
Heyz,
Cheers,
Mike
Cheers,
Mike
hmmm,,,,, or sandblast for the bottom part. looks neater. i will not do film.... bubbles might appear.
I meant most of the time the glass door will be open.... cos aircon might not be on most time unless that is guest? mahjong... or hot hot hot day.
ya... will ask my contractor is do total cleaning ....
Not much difference. One is wood one is rubber. Price also similar range.
Cheers :yamseng: ,
Jaskel
Cheers :yamseng: ,
Jaskel
Ha ha... make up my mind...... go the vinyl ones..... anyway only lay at the raise platform.
sample vs the old damage laminated floor
Edited by Tigaroo
Day 9,,,,
Book PUB Gas appt.... the pipe installer came on time to lay the gas pipe to my stove area... the 2 installer very friendly.
