vex
Change From Instant To Storage Heater
Anyone changed their instant heater to storage heaters before ? Am deliberating this due to improved water flow (low water pressure). beside changing the unit to a storage tank, what other changes are to be done, like changing the pipe ? Is the pipe change optional ? Will City gas do the pipe change ? Pls share, thanks a lot !
City gas will only run the gas pipe for you to connect to heater as for water pipe you have to find your own plumbler.
:yamseng:
yeah. depends if your toilet got bath tub or not, that would ascertain how many litre of storage tank that is needed.
if u want plumber, i can recommend u. just pm me
