rocksoft
Granite Change Color
need help again!!!!
my granite flooring changed color when rain splash in... some part were dried but there is a portion that the color didn't fade to its original color and it has been like a month....
any solutions?
  On 5/27/2012 at 3:17 PM, rocksoft said:
need help again!!!!
any solutions?
The red col granite slates covering the exterior wall of Taka also same like yours; bake under hot sun for a day or 2, the water mark will disappear. Check with your contractor how you can waterproof your granite.
I don't think U can withdraw the water marks on your granite as I tried before
U go suntec city the entrance near to ducktour booth U c the flooring have dark patches those r caused by water marks
Bo bian coz its porous by nature
mai everything also say cannot lah... google is seriously your best friend. :thumbs up:
http://www.howtocleanstuff.net/how-to-remove-stains-from-granite-countertops/#WaterStains
Edited by taichipanda
Thanks for googling. I've just got my granite stained and this really help me a lot. My stains are removed with vinegar.
hey taichipanda thanks for the link.. yeah mine is not hardwater stain but like the granite darken after the water is absorbed into the stone.
the water didn't only enter from the surface of the stone but also underneath by the crack in the skirting and down underneath (if you roughly know what i mean, not v good at articulating)
i try using hairdryer to let the water evaporate but it still doesnt work, on the fan for 24hrs also useless. Now i buy a big and cheap spotlight to shine at and heat the stone. Hopefully it will acceralate the evaporation process.
you mean ordinary vinegar?
Granite darken after the water is absorbed into the stone is equal to hardwater stain. You can try apply granite sealer for waterproofing after you get the hardwater stain off.
Btw, have you even try using white vinegar?
If money no issue to you, you can consider changing your granite to quartz surface.
