VERT
Fire Extinguishers - Psb Tested
The EVERSAFE range of dry powder extinguishers is certified to SS 232:1999 (PSB Tested) as well as BS EN3: 1996 and is manufactured under an ISO 9001 approved Quality System. Extinguishers are available in wide range of sizes. The cylinders are fully deep drawn from cold rolled steel, and pressure tested to twice the extinguisher's working pressure. Cylinders are externally coated with polyester (with phosphate under treatment) for maximum corrosion resistance and have passed the 480-hour salt spray test.
The EVERSAFE range of dry powder extinguishers is charged with specially fluidised and siliconised mono ammonium phosphate powder which offers resistance to compaction where the extinguisher is installed in a location subjected to vibration. It is safe and effective for use on Class A (carbonaceous), Class B (flammable liquid) and Class C (flammable gas) fires and also suitable for use on live electrical fires.
Specifications: -
Type: Stored Pressure Type
Extinguishing Medium: ABC Dry Powder
Capacity: 1.0 kg
Propellant: Dry Nitrogen (N2)
Valve: Controllable Chrome Plated Brass Valve with Pressure Indicator
Body Diameter: 80 mm
Overall Height: 332 mm
Approx Full Weight: 1.9 kg
Working Temp Range: - 20°C to + 60°C
Working Pressure: 12 Bar @ 27°C
Test Pressure: 25 Bar
Burst Pressure: Exceeds 69 Bar
Approx Discharge Range: 2 m
Approx Discharge Time: 7 sec
Fire Rating: 5A:21B
Coating (Internal): Stoving Epoxy Primer
Paint Finishing: RAL 3000 Flame Red Polyester Powder Coating
Mounting: Plastic Vehicle Bracket
Manufactured & Certified to SS 232:1999 and BS EN 3:1996
Contact VERT Solutions LLP at: -
Tel: 65-6226-1370
Email: enquiries@vertsolutions.com.sg
Website: www.vertsolutions.com.sg
Hi, how much is this 1kg ABC fire extinguisher? Any delivery?
The price of 1kg ABC fire extinguisher is S$40.00. This is a promotional price and is valid only till end May '12. Thanks!
How much is EED-2 ? Where can i get it? Got delivery?
You can contact us for the purchase and delivery. Tel: 6226-1370. Thanks!
Just came back from Kallang Leisure Park.. So disappointed rush there after work NOT a single EED series there. Those little stock there
no discount price at all. Discount only for AA member..Public purchase at full price.. Haiz...
Sorry for the inconvenience. You can contact us directly for the purchase. The Eversafe 1kg ABC Dry powder fire extinguisher will be available at AA Shops from June. Thanks.
