Minerat
Advice Required. Do I Need An Id?
Dun ever put deposit before anything... I also have experience with some firm at expo... lucky the one I engaged didn't and also provide.free 3D before I sign with them...
First of all have you ever been into any reno stuff before? Cause i can tell you from my DEC reno its not easy to settle A reno without a ID or a contractor that can handle all the stuffs you mention above. Therefor do get a ID that is able to help you & your wallet & do not sign with any expo company unless you are 100% sure to get a deal with them even there is the free 3D drawning OF OTHERS FREEBIES cause you will be drawn by the design instead of what you really wants to be done in your simple reno .Just my 2 cent of advise ;) if u need intro u might wan to pm me as my reno was done 6 mth ago and everytihing still going well "touch wood "
Hi Minerat,
The extent of your works are quite similar to mine. I would suggest getting quotes from both contractors & ID. My experience with contractors weren't good, of the 3 I gave plans to, only 1 gave a proper quote, & he wasn't much cheaper than the IDs because he has cheap lobang for some areas but some areas he's more ex. The other 2 contractors, both having threads in this forum, I had to chase & chase. 1 of them never got back to me at all despite his promises.
I got quotations from 2 IDs as well. In the end I went with the ID team my hubby & I had chemistry with & could give a competitive quote & whose track record is good in this forum.
I know what I want to do too, & am very vocal in my communication of concepts & look of my house. I didnt think I needed an ID too but I must say that the ID has value added so far in fresh ideas along the concept I want. Because of their experience & long term working relationship with the various subcons, project management is a huge value add given the scale of the Reno works & the slightly different & more unpredictable issues that might crop up for a landed house, as opposed to a HDB's.
My 2 cents worth.
Hi can you give me yr id contact? Thanks
