bepgof 20 Report post Posted May 22, 2012 Whaaa...your theory again. Appliances where got dead? all are part of nature, tio bo?Like to explain how earth benefits fire?Never witness "earth"(臭土)when adds water, gives FIRE?(U would know if u were born 20 yr earlier). In 1999, when I was in a gas plant in a Brazil jungle, I witnessed the "earth" burnt all by itself (natural gas underneath). Earth helps producing fire, actually this is an "extreme" case. Generally, WOOD benifits/produce FIRE. Nowaday, "many things" can produce fire, or "anything" can produce fire, knowledge is the limit. All from dust, will be returned to dust(earth).You should know by now what is called "habitat". No lives no happening of events. A gun won't trigger by itself, simple "theory" right? Lives make things appear to be complicated, luckily there are "laws of nature" which govern the rules. Share this post Link to post Share on other sites
kcwee 8 Report post Posted May 23, 2012 Never witness "earth"(臭土)when adds water, gives FIRE?(U would know if u were born 20 yr earlier). In 1999, when I was in a gas plant in a Brazil jungle, I witnessed the "earth" burnt all by itself (natural gas underneath). Earth helps producing fire, actually this is an "extreme" case. Generally, WOOD benifits/produce FIRE. Nowaday, "many things" can produce fire, or "anything" can produce fire, knowledge is the limit. All from dust, will be returned to dust(earth).You should know by now what is called "habitat". No lives no happening of events. A gun won't trigger by itself, simple "theory" right? Lives make things appear to be complicated, luckily there are "laws of nature" which govern the rules.alama...what 'smelly earth', think we sua ku.....should be the earth got sulphur or nitrogen gas that easily combustible la! This is called hot earth, different from wet earth Share this post Link to post Share on other sites
bepgof 20 Report post Posted May 23, 2012 知之为知之,不知为不知,知也。臭地放臭气,臭人放臭庇。 Share this post Link to post Share on other sites
kcwee 8 Report post Posted June 4, 2012 知之为知之,不知为不知,知也。臭地放臭气,臭人放臭庇。知之为不知,谦也不知而言知,奥也和而不同,同而不和,散也 Share this post Link to post Share on other sites
