Gymrat76
Question On Electrical Works
What happen if I install 10 13A SSOs in single loop using 16A MCB and 2.5mm wire?
2 things happen: something happens and nothing happens. :bangwall:
I've said 2.5mm cable can carry contineous 5A safely. This size can carry 230 x 5 x 0.8 = 920 watt of load!
I've also said, PVC cable insulation can last up to 70 deg C (actually this is the "design temperature"), practically, pvc lasts till 105 degC, before its electrical characterists varnish/give way.
As rule of thumb again(cos too many copper alloys in mkt) if current capacity up to appro 6 times its mm sq size (2.5 x 6 = 15A) it will reach 105 degC within seconds!.
All this stuff is so complicated!
I don't understand any of this.
Can I ask something relatively simple?
We are getting our keys soon and all new HDB flats are supposed to be provided with a 40 amps main switch.
Is this capable of running all the usual household appliances (TV/Microwave/2-Door Fridge etc) in addition to a built in oven (16 amps), air conditioner, and still allow us to install an induction hob?
From what I've seen, most induction hobs require 30-32 amps.
So if I install one, would that mean that I cannot run any of my other household appliances at the same time?
Hope to hear back from someone about this before we get around to buying all our appliances. :)
Thanks in advance!
Edited by kevenang
