Akitsuki
Serangoon North Renovation By Defong Interior Design
  On 5/8/2012 at 6:33 AM, taichipanda said:
Pardon me but this is the first time i heard of 2 burners tac tac tac at the same time, maybe is normal to Technogas, better to check with their technician.
We called Technogas and they verified that their hob ignitor will tac together even if we are turning only one knob. The stoves all share the same ignitor. I can only think of the con side is that if the built-in ignitor spoil, then we need to use the ignitor gun to turn on the fire, or worst scenario is need to change a new hob.
Technogas will be coming this Friday to check on the tight knob.
  On 5/8/2012 at 6:27 AM, taichipanda said:
I am using Rinnai RB-2CG, 2 burners, battery ignition.
I am using the same method found on this blog to ignite the fire - http://renovation-greencoal.blogspot.com/2008/05/using-rinnai-inner-flame-burner-hob_6584.html
1 - Push down the burner flame knob and gently turn anti-clockwise until you reach resistance i.e. you feel the knob cannot be turned further. That resistance signals the "end" of the knob-turn but do not let go of the knob yet, continuing to pushing it down.
2 - As you continue to push the knob down, turn a bit more anti-clockwise until you meet resistance again. At that point you then turn back the knob in a clockwise direction until you hear a "click" sound. That' a "locking" indication you've turned on the fire successfully.
I think I know what you mean. Need "practice" so we can get used to using this kind of hob
actually i thought once you ignites the sparks, all will be ignited. last time i used another brand at my previous previous place, also like that. and its electric ignitor, not battery. so i thought its all the same, whether its electric ignitor or battery operated.
Maybe we didn't take extra notice when using other brand stoves. Technogas ignitor is very obvious. We can see "electric spark" on two stove when turning a knob only. And the problem to hold the knob for awhile before release the knob when fire is stable, makes us more worried why like that. Other brands just press the knob down and turn, fire will light up immediately, so we may not notice if ignitor will spark for the other unused stove
Same. The others have spark as well when I turn one.
I think new model stoves are like that. If the stove start-up is fast, we may not notice the sparks for the unused stoves. For mine, the start-up is slow, hence we notice the other stoves spark together when we are trying to turn on the gas for one of the stove.
I just tried to turn the knob anti-clockwise then clockwise, it does not work. I tried turning the knob anti-clockwise and "feel" a "click", I released the knob, the fire is there, means the fire is stable to release the knob. But it does not always work for the first trial. I achieve that after 2-3 trial.
I turned then have wait a while for it to tic tac tic tac
  On 5/8/2012 at 9:24 PM, romeltic said:
Hi ayazumi,
Can provide me with your carpenter contact? I would love to have a similar tv console like yours :)
AYA 小知识
During tiles inspection time, how do you indicate on the hollow tile(s) so that your tiler can notice instantly?
Method: Tear a piece of masking tape, stick on the hollow tile, and draw a X on the masking tape. Use red, black, or blue marker
Question: Do you need to label the masking tape exactly where the hollowness is?
Answer: Don't need! Your tiler is not that stupid. He will knock on the hollow tile if it is really hollow, or tiny bit of hollowness before he changes the tile for you.
Lastly, do not commit this mistake as shown in the picture below.
This is the most funniest XX signs I have ever seen. What a joker.
Actually it is not funny at all. First, tilers are not blind men. One X is enough, why so many XX? Second, why create such problem for your tiler/contractor/ID? In the end trouble people to clean the XX from the tiles if found not "really hollow". Third, one shouldn't even draw on the tile.
Edited by ayazumi
  On 5/1/2012 at 12:56 PM, ayazumi said:
Our art room
Shelves for our canvas drawings. Still looking for tough string to tie the shelving.
I simply love the DIY bird cage pendant lamp. It's very personal and classy. Your hubby did a fantastic job at it.😃
