brassdoor
Caution. Please Read To Prevent Electric Shock
I found the wiring connection above my bathroom water basin & tap to be UNinsulated. If there is water splash from the tap / basin ( especially when you have young children play water), there is risk of short circuit or worse, electric shock.
SEE PICS below.
I notified my designer / electrician and he came within 20mins to tape up the exposed wire connection.
He will also notify his company boss and check with all his existing renovation customers on this.
Please check all lighting / wiring under your kitchen and toilet sink for your own safety.
http://www.flickr.com/photos/31970920@N02/6823308812/
http://www.flickr.com/photos/31970920@N02/6823308802/
Edited by brassdoor
I found the wiring connection above my bathroom water basin & tap to be UNinsulated. If there is water splash from the tap / basin ( especially when you have young children play water), there is risk of short circuit or worse, electric shock. SEE PICS below.
I notified my designer / electrician and he came within 20mins to tape up the exposed wire connection. He will also notify his company boss and check with all his existing renovation customers on this.
http://www.flickr.co...N02/6823308812/
http://www.flickr.co...N02/6823308802/
Edited by brassdoor
merge 2 same topic into the same thread.
In the 1st place, the wiring should not be hanging in the air.
