papaedmund
Diy Tv Feature Wall And Console
hi i would also like to diy a feature wall,
can you tell me what is the material required to do a feature wall?
Material for feature wall:
1.Normal MDF board or plywood and paint it over
2.Normal plywood and laminate it with strips design
3.Normal playwood and wallpaper it
All these need some carpentry skill to mount it to wall.
Cheers! :D
u do pole system wardrobe with those clothes hanger, wire basket and glass sliding door? partition can use acrylic plastic? no wood
Yes,alluminium pole systems,baskets or cabinet.
You mean glass sliding doors for the wardrobe?
Glass sliding frameless? or alluminium frame?
You need to have partition at both sides to put up for sliding doors.
You need wood frame partition to hold up the acrylic or glass.
BTW acrylic is not recommended...glass is better.
Regards,
papaedmund
Regards,
papaedmund
I worry wood get mouldy. Pole system wardrobe with sliding door. Can hold on both wall? Like those sliding door use metal track n metal frame? Pm me ur price. 5-6 ft
