kim76
Types Of Kitchen Sinks
  On 3/15/2013 at 2:39 PM, kim76 said:
That's good advice.. U got a name for the epoxy? Since there are so many in the market. I probably will get one to try it out!
Thanks! :yamseng:
I used Selleys epoxy putty underwater version. So far so good. Abt 1 or 2 tubes will be enough. Very useful even in bathrooms or anywhere that you want to seal up preventing water from sipping through
Thanks! I will get a tube to try out.. :good: :good:
  On 3/16/2013 at 1:15 AM, dragonnite said:
wah, cool...let me know how it works and ... how to do it myself :sport-smiley-004: !
This is what I did
  On 3/16/2013 at 1:55 AM, yokechye said:
This is what I did
wah, so neat ! :good: need any tools ? errr, and which selley's putty did u use ? i checked online, so many types !! :jawdrop: dunno which one to buy :unsure:
All you need is a pen knife to cut the putty and use your fingers to knead it cos there are 2 epoxy that you need to combine. The 2 epoxy is in 1 tube. It's quite sticky so you need to wet your fingers abit to make the putty smooth after sticking it on.
I got the underwater version which I feel more suitable for sinks. Try to do it at small amount at a time cos it tends to get bit messy n tiring. My neck also tired after bending do much. Haha
orrr, this one ah ?
eh, why not this one leh?
  On 3/16/2013 at 4:44 AM, dragonnite said:
orrr, this one ah ?
Hmm... I didn't see the aqua version that time. But I think also ok ba. The 2nd one is silicon. It's different. Silicon will grow mould sooner or later and will deteriorate. Putty last longer and is very solid when dry
eh...can take a picture of wat u r using? den I ask the guy in the shop wat is the difference. ..
this one
Edited by yokechye
  On 3/17/2013 at 7:47 AM, TwinkleBell said:
Hi Kim & other brothers and sisters ,
My plumber had no issue in fixing my Kraus vessel tap though it stated US plumbling fitting :)
Cool... Your plumber must hv experience...
I believe you are going to get lots of PM on your plumber's contacts.... :sport-smiley-004: :sport-smiley-004:
  On 3/17/2013 at 12:49 PM, dragonnite said:
both selffix and homefix dun stock the other one so i ended up buying the same thing as you... :D
hehe... I don't remember seeing the aqua version as well
