Terrain1976
Please Help To Advice On My Quotation - 4 Rm Resale
Hi to all..
Just received the below quotation. Can advice if the below quote sounds reasonable? Thanks in advance.
Living & dining hall
01. To demolish wall between 2 b/room. $ 200
02. To construct new store room with hollow block. $ 1190
03. To construct lintel to support wooden doors frame. $ 100
04. Supply & install wooden door frame & nyatoh door with varnishing. $ 430
05. To dismantle wardrobe & shelve @ b/room 3. $ 180
06. To demolish existing store room & kitchen ent. wall. $ 300
07. To make smooth new dining area wall. $ 280
08. To level up new dining area floor with cement screed. $ 350
09. Supply & construct false ceiling @ living & dining hall as show in plan. $ 980
10. Supply & construct cove light as show in plan 26ft. $ 320
11. Supply & fabricate W300mm full height laminate feature wall with cove light. $ 480
Total: $ 4810
Kitchen
01. To demolish wall & floor tiles, dismantle low cabinet. $ 1200
02. Supply & lay wall tiles up to ceiling height. $ 1750
03. Supply & lay homo. floor tiles. $ 700
04. Supply & apply chemical waterproofing membrane. $ 120
05. To construct cement base. $ 280
06. Supply & change s.steel rubbish chute. $ 180
07. Labours to install existing window grills. $ 50
08. Design & fabricate 24ft top & bottom cabinet with laminate soft closing doors, s.steel dish
Dryer with alum frame glass doors & 1 row drawers. $ 2840
09. Supply & install 13.5ft solid surface work top. $ 945
Total: $ 8065
2x toilets
01. To demolish wall & floor tiles. $ 900
02. Supply & apply chemical waterproofing membrane. $ 240
03. Supply & lay wall tiles up to ceiling height. $ 2340
04. Supply & lay homo. floor tiles. $ 700
05. Supply & install design bi-fold door 2 set. $ 560
Total: $ 4740
Plumbing works
01. Supply & install s.steel piping to whole house. $ 750
02. Labours to install sink taps, pvc inlet & outlet pipe. $ 120
03. Labours to install 2 w/c, 2 basin with taps. $ 360
04. Labours to install 2 instant heaters. $ 120
05. Labours to install 2 toilet accessories. $ 80
Total: $ 1430
Re-wiring
01. Supply & install: 26 lighting point & installation of light. $ 1040
2 nos heater point (2 toilet) $ 180
3 set 1 x 13 amp single socket outlet (fridge & washing machines) $ 150
9 set 2 x 13 amp double socket outlet. $ 495
1 nos cooker hood point with neon light switches $ 85
2 nos Scv cable point. $ 180
2 nos phone point. $ 90
1 nos microwave point with neon light switches. $ 85
2 nos heater point & 1 nos a/c point in 15amp. $ 285
New 16 way D/B box. $ 420
Total: $ 3010
Miscellaneous
01. To paint whole house with emulsion paint, pvc pipe with gloss paint.(ici or Nippon) $ 1450
02. General works: acid washing & clearing window when job done. $ 240
Total: $ 1690
Sub Total: $ 23745
Hi to all..
Total: $ 4810
Kitchen
Total: $ 8065
2x toilets
Total: $ 4740
Plumbing works
Total: $ 1430
Re-wiring
Total: $ 3010
Miscellaneous
Total: $ 1690
Sub Total: $ 23745
Hi, I researching for reno quotes for my 4rm resale flat also. Do you think you can share the contact for your quote with me? Thks!
Reasonable only that Your quote seems slightly higher than mine, and yet there are those lesser than ours.
eg, your bi-fold cost you $280 when mine is $180, your demolishing toilet cost you $900 when mine is $580.
The rest is abit difficult for me to compare because I am not sure what is your sq area. I would suggest things like installation of water heater to be removed as most shops I ask, when you buy water heater from them, they provide free installation given that there is already the switch. I am rewiring my 5rm at the same price as yours, so I assume its much ex as mine has 'L' box lighting too... I suggest to get a different electrician and not from ID. Saves me alot.
Hi to all..
01. To demolish wall between 2 b/room. $ 200 SOUND OK, SHOULD B LESS THEN 8FTS
02. To construct new store room with hollow block. $ 1190 HOW MANY FT BY HOW MANY FT? NORAMLLY THEY CHARGE 80-100 PER FTS. NOT INCLUDE DOOR AND FRAME
03. To construct lintel to support wooden doors frame. $ 100 ?????
04. Supply & install wooden door frame & nyatoh door with varnishing. $ 430 AROUND THER
05. To dismantle wardrobe & shelve @ b/room 3. $ 180 REASONABLE
06. To demolish existing store room & kitchen ent. wall. $ 300 SOUND OK
07. To make smooth new dining area wall. $ 280 OK
08. To level up new dining area floor with cement screed. $ 350 HMMM SOUND OK
09. Supply & construct false ceiling @ living & dining hall as show in plan. $ 980 NOT TOO BAD
10. Supply & construct cove light as show in plan 26ft. $ 320 NOT TOO BAD
11. Supply & fabricate W300mm full height laminate feature wall with cove light. $ 480 NOT TOO BAD
Total: $ 4810
Kitchen
Total: $ 8065
2x toilets
Total: $ 4740
Plumbing works
Total: $ 1430 JUST LABOUR AND PIPE? 1200 WILL BE A GD CATCH
Re-wiring
Total: $ 3010 GET A ELEC MAN YOUR SELF TO SAVE UP TO 500
Miscellaneous
01. To paint whole house with emulsion paint, pvc pipe with gloss paint.(ici or Nippon) $ 1450 HMMM 1200 CAN GET LE
02. General works: acid washing & clearing window when job done. $ 240 AROUND 200
Total: $ 1690
Sub Total: $ 23745
HACKING AND DISMANTLE COST YOU 2780? SOUND X, HOW MANY ROOM IS THIS
TILING BOUT 8050, HAVE TO SEE WHAT TILES THEY PROPOSED, BUT CANT ASK MUCH AT THIS PRICES LA. UNLESS U R INTO NICE AND DESIGN TILES, THEN PREPARE TO PAY MORE FOR ADD ON HAPPI RENO
Hi, do you mind to pm me your id contact as well as quote .
I'm looking for id for my 3rm flat.
quote name='Terrain1976' timestamp='1329963573' post='695955']
Hi to all..
Total: $ 4810
Kitchen
Total: $ 8065
2x toilets
Total: $ 4740
Plumbing works
Total: $ 1430
Re-wiring
Total: $ 3010
Miscellaneous
Total: $ 1690
Sub Total: $ 23745
Hello!
Looks reasonable. Some works are cheaper while others are slightly more expensive. So depends on quality and workmanship and service as well.
Happy renovation! Have a smooth sailing one.
Cheers,
Mike
Hi there,
It's cheap. Hmmm... Take note of the quality and workmanship tho. For example, what material are they using for your kitchen countertop? What kind of tiles are they using?
And also there might be missing items like floor protection, haulage, etc. All these so called hidden cost when amount together will become significant. So be sure to double confirm with your ID or contractor.
Have a smooth sailing renovation! Have fun!
Cheers :yamseng: ,
Jaskel
