twk
Need Help With This Quotation For 5I 122Sqm
A) Master Bathroom
1) To provide labour and materials to lay ceramic wall tile to ceilling height using tile adhasive over existing tile.(Tile@<$2.50/Sqft) SGD 1,650.00
2) To provide labour and materials to lay homogenous floor tile.(Tile@<$2.50/Sqft) SGD 500.00
3) To construct and install top & bottom vanity cabinet in laminate finish c/w Abs trimming and mirror.(L1500mm) SGD 1,500.00
4) To supply and install Solid Surface for vanity Top (L1500mm) SGD 380.00
5) To supply and install tempered glass frameless shower screen c/w temered glass SGD 960.00
Swing door for 2nos bathroom.@$480.00
6) To supply and install tempered glass swing door at bathroom entrance. SGD 680.00
B) Living, dining and Bedroom Area
1) To construct and install plaster glass false-ceilling and light box. SGD 1,250.00
2) To construct and install Tv console c/w low cabinet and feature wall in laminate finish. (L3000mm) SGD 2,800.00
3) To construct and install box up at bedroom entrance using venner ply in vanish. SGD 480.00
4) To provide labour and materials to lay 600x600mm homogenous floor tile(gloss)**** ,dining and storeroom using tile adhasive over existing tile. ( Tiles@<$3.00/Sqft) SGD 2,500.00
5) To supply and install laminate flooring to 4nos bedroom c/w skirting. SGD 2,450.00
6) To Construct and install partition wall with rock wool between studyroom and living. SGD 480.00
C) Master Bedroom & Studyroom
1) To construct and install full height wardrobe in laminate finish c/w ABS trimming and anti-slam door. (L3000mm) SGD 2,300.00
2) To construct and install suspended study desk c/w drawer in laminate finish.(L1500mm). SGD 580.00
3) To construct and install false-ceilling and light holder. SGD 1,050.00
4) To seal up existing wall using gypsum board . SGD 380.00
D) Balcony
1) To provide labour and materials to lay homogenous floor tile c/w tile skirting. SGD 650.00
2) To construct and install box up using venner ply in vanish finish. SGD 580.00
3) To construct and install plaster glass false-ceilling. SGD 280.00
E) Bedroom 2
1) To construct and install wardrobe in laminate finish c/w ABS trimming and anti-slam door.(L1800mm) SGD 1,350.00
2) To construct and install L-shaped light box . SGD 350.00
3) To construct and install suspended dressing table c/w drawers in laminate finish (L750mm) . SGD 300.00
4) To construct and install suspended study table c/w drawers in laminate finish SGD 360.00
(L900mm)
5) To construct and install feature in laminate finish(L1000mm) SGD 780.00
F) Bedroom 3
1) To construct and install wardrobe in laminate finish c/w ABS trimming and anti-slam door.(L1650mm) SGD 1,250.00
2) To construct and install L-shaped light box. SGD 350.00
3) To construct and install suspened study table c/w drawers in laminate finish (L1500mm) SGD 580.00
4) To construct and install side table c/w drawer in laminate finish.(L450mm) SGD 350.00
5) To construct and install feature wall in laminate finish(L1000mm) SGD 780.00
6) To construct and install single bed base in laminate finish.(L1000x1800mm) SGD 650.00
7) To construct and install false wall using gypsum board.(L900x2400mm) SGD 180.00
Hauladge Work
SGD 1,500.00
1) To provide labour and tools to demolish existing hollow block wall between studyroom and master bedroom..
2) To provide and tools to demantle existing wardrobe,cabinet,Wc bowl,basin, un wanted items and disposal.
3) To provide labour and tools to hack off existing tiles skirting.
4) To provide labour to deliver tile,cement,sand and other wet work materials on site
5) To provide labour to clear all debris after completion of wet work.
G) Door and Door Frame
1) To supply and install timber 1no door frame in oil painting finish.$120.00 SGD 120.00
2) To supply and install 3nos bedroom door c/w lever lock set and magnet stopper using veneer ply in vanish finish@$350.00. SGD 1,050.00
3) To construct and install laminated Tic-Tac door for store room SGD 480.00
H) Electrical Work
1) Supply and install 40nos light point @$35.00 SGD 1,400.00
2) Supply and install 6nos 2x13A power point @$70.00 SGD 420.00
3) Supply and install 1 set 16 Way new DB SGD 580.00
4) Supply labour to install 40nos light fitting@$12.00 SGD 480.00
5) Supply labour to install 4nos ceilling Fan @$50.00 SGD 200.00
I) Plumbing Work
1) Supply and install stainless steel inlet and outlet water pipe for both bath room only. SGD 750.00
2) Provide labour to install 2nos sitting WC bowl @$80.00 SGD 160.00
3) Provide labour to install 2nos basin and tap.@$50.00 SGD 100.00
4) Provide labour to install 2nos bath mixer and shower set.@$50.00 SGD 100.00
J) General
1) To provide labour and materials for whole house emulsion painting inculde door frame and exposed PVC pipe.(ICI or Nippon) SGD 1,350.00
2) To provide labour and materials to plaster existing grove line wall and ceilling. SGD 250.00
3) To supply and install Mitsubishi Inverter System 3 Air-Con for 3nos bedroom. SGD 2,950.00
Total: SGD 40,620.00
I find it quite reasonable, for your info, I was quoted as follows:
1) To provide labour and materials to lay ceramic wall tile to ceilling height using tile adhasive over existing tile. SGD 1200.00
2) To provide labour and materials to lay homogenous floor tile. SGD 400.00
5) To supply and install tempered glass frameless shower screen c/w temered glass and kerb SGD 1260.00
Swing door for 2nos bathroom.@$630.00
For the laminate floor, assume that total area of your rooms are 700sqft, so S$3.50 psf. You may want to find out what brand the contractor is using, laminate floor range between S$2.50 to S$6 / S$7. Anyway I trust that it should be cheaper if you get the laminate floor company to do it for you.
Also for your info, the shower screen is less than S$400 if you get direct from glass work company.
Price does play a part but I think the smooth process and end product is more important as you will be using it for a few years therefore it is important not only looking at the price.
Hi thks for the advice to those replied ,i have ask my id to remove those items like glass swing door and also i have decided to do up the kitchen. This is the reviced quotation . Pls kindly help with those items that i can save like glass swing door if i go direct. Should i go direct for my wardrobe and how much will i save if i do ?
A) Master Bathroom
5) To supply and install tempered glass frameless shower screen c/w temered glass SGD 480.00
Swing door.
B) Living, Dining and Bedroom Area
3) To provide labour and materials to lay (1200x600mm) homogenous floor tile(gloss)****,dining,master bedroom,studyroom,balcony and storeroom using tile adhasive over existing tile c/w tile skirting.(Tiles@<$5.00/Sqft) SGD 6,800.00
4) To supply and install laminate flooring for bedroom 2 & 3 c/w skirting. SGD 1,350.00
5) To Construct and install partition wall with rock wool between studyroom and living. SGD 480.00
2) To construct and install false-ceilling and light holder. SGD 1,050.00
3) To seal up existing wall using gypsum board . SGD 380.00
D) Balcony
E) Bedroom 2
F) Bedroom 3
5) To construct and install false wall using gypsum board.(L900x2400mm) SGD 180.00
Hauladge Work
1) To provide labour and tools to demolish existing hollow block wall between studyroom and master bedroom.. SGD 2,300.00
6) To provide labour and tools to demolish existing hollow block wall between kitchen and dining.
7) To construct a new kitchen entrance at balcony and make good.
8) To provide labour and tools to hack off existing sink & cooker support.
H) Electrical Work
I) Plumbing Work
J) General
K) Kitchen
1) To construct and install top & bottom kitchen cabinet in laminate finish c/w dish drainer,ABS SGD 2,600.00
trimming and anti-slam doors.(L3350mm)
2) To construct and install full height storage cabinet at service balcony in laminate finish c/w ABS trimming anti-slam doors. SGD 1,150.00
3) To supply and install solid surface for kitchen work top.(3650mm) SGD 840.00
4) To provide labour and materials to lay homogenous floor tile using tile adhasive over existing tile.(Tiles@<$2.50/sqft) SGD 1,200.00
5) To provide labour and materials to lay Ceramic wall tile using tile adhasive over existing tile to ceilling for exposed area only.(Tiles@<$2.50/sqft) SGD 2,400.00
6) To supply and install 3nos 12mm thick tempered glass fixed panel between kitchen and dining. SGD 1,600.00
Total: SGD 46,370.00
Are you asking advice on how to save cost? IMO, you can reduce carpentry work like tv console, feature wall unless really necessary. (for example you have an odd-shape living room) I find these items not only take up space but also limit your way of rearranging furniture. It will go outdated eventually. If you intend to sell your house after some time, usually buyer will tend to look for houses with minimal built-in to reduce cost of hacking. Just my 2 cents
You can save cost in the installation of lighting where when you buy the lights for your house you can tell them to install for you instead of you paying $12 for each light.
