fongfamily01
Mitsubishi Non Inverter R22
Anybody purchase a Mitsubishi Non Inverter System 1 & System3 recently?
What's the quote like?
I found out that Gaincity is not carrying any R22 Non-inverter Mitsubishi system anymore.
Is there other recommended place to purchase the unit?
R22 will be totally phase out by 2015, so why still want to buy such unit? Even if you can get it, will will have problem topping up the refrigerant in future.
The reason why i'm doing it is because i don't wish to change the piping as renovation just done abt a year ago.... :(
Given a choice, i would go for the R410 and I don't need to search high and low....
I thought the r22 will only be phase out by 2016?
Edited by fongfamily01
Yup. you're right.... 2016
http://singapore-aircon-r410a.blogspot.com. Didn't know what R410 and R22 requires different pipings....
Based on the information I'd collected, it's due to the higher pressure of R410. Thus, it required thicker and bigger pipe for the R410. Those pipe used by R22 are generally too thin and cannot sustain the pressure of R410.
Is it most shop using R410A? courts feb 18-19 promotion 10set per day panasonic inverter system 2 @ $1835 free standard installation + $40 delivery + $20 dismantle = $2025. harvey norman MIT $1885. can buy from them or not? but i enquiry from courts they using sub contractor. why not their own worker?
how much to seal door air vent?
u can check ECCatalogue, NEA database of registered good
Edited by dean
R22 gas will still in production after 2016.
2016 shoud be the date for phasing out equipments using r22 gas.
As there are still many equipments using r22 gas after 2016.
R22 gas might be totally phased out only after > 2021 (IMO)
Edited by terumo
