CygnusX
Seek Advice On Reno Quotation
Got below quote for my 3 bedroom condo (relative good condition).
I think its expensive.
Anyone care to help comment/review/advise?
Thanks.
S/N Job Description Qty//Unit//UnitPrice//Amount (S$)
To provide labour and tools for:
1. Shift ext'g lighting 8 /nos/ $45.00/ $360.00
2. New 2x18watts lighting 8 /nos/ $60.00/ $480.00
3. New 2 X 13amp power point 4 /nos/ $70.00/ $280.00
4. Install ext'g bomb shelter door exclude material 1 /lot/ $120.00/ $120.00
5. New single bowl s/steel sink ,tap and piping 1 /lot/ $800.00/ $800.00
6. Paint works for whole area using emusion paint exclude door and door frame 1 /lot/ lsum/ $1,700.00
7. Joint back ext'g false ceiling at guest rm and kids rm 1 /lot/ lsum/ $600.00
8. Restain ext'g parquet at 3 beds room 1 /lot/ lsum/ $1,200.00
9. Dismantle ext'g cabinet (master rm ,kitchen and living) 1 /lot/ 1sum/ $1,300.00
10. Polish ext'g flooring **** area 1 /lot/ lsum/ $1,200.00
11. KIDS AND GUEST ROOM
TO SUPPLY LABOR TO FABRICATE KIDS ROOM AND GUEST
ROOM WARDROBE CABINET C/W ALUMINIUM SLIDING
DOOR WITH 1 PANEL FROSTED FILM AND 1 PANEL MIRROR
INTERNAL BODY IN WHITE POLYGAN AND EXTERNAL IN
P/LAMINATE FINISH.
SIZE(1500 X 650 X 2540)MM GUEST ROOM 1 /lot/ lsum/ $2,600.00
SIZE(1500 X 650 X 2540)MM KIDS ROOM 1 /lot/ lsum/ $2,600.00
12. MASTER AND GUEST ROOM
TO SUPPLY LABOR TO LAY GRANITE TOP AT EXT'G
WINDOW AT GUEST ROOM AND MASTER BED ROOM.
SIZE(1990 X 510 X 18)MM MASTER ROOM 1 /lot/ lsum/ $1,120.00
SIZE(1990 X 510 X 18)MM GUEST ROOM 1 /lot/ lsum/ $1,120.00
13. MASTER BED ROOM
TO SUPPLY LABOR TO FABRICATE BED HEAD PANEL C/W
FABRIC AND BOTH SIDE WITH P/LAMINATE AND 2NOS
OF SIDE TABLE .
SIZE(2815 X 100 X 2600)MM BED HEAD PANEL 1 /lot/ lsum/ $2,600.00
SIZE(450 X 400 X 600)MM SIDE TABLE CABINET 2 /nos/ $400.00/ $800.00
14. MASTER BED ROOM
TO SUPPLY LABOR TO FABRICATE QUEEN SIZE BED C/W
4 NOS OF DRAWER IN P/LAMINATE FINISH.
SIZE(1900 X 1900 X 400)MM 1 /lot/ lsum/ $1,800.00
15. MASTER BED ROOM
TO SUPPLY LABOR TO FABRICATE DRESSING TABLE WITH
DRAWER INTERNAL IN WHITE POLYGAN AND EXTERNAL
IN P/LAMINATE FINISH.SIZE(1700 X 400 X 250)MM 1 /lot/ lsum/ $900.00
16. DINNING AREA
TO SUPPLY LABOR TO FABRICATE LOW CABINET BESIDE
DINNING TABLE WITH SWING DOOR OPENNING AND
INTERNAL IN WHITE POLYGAN AND EXTERNAL IN
P/LAMINATE FINISH.SIZE(1220 X 600 X 900)MM 1 /NOS/ /1SUM/ $600.00
17. KITCHEN CABINET
TO SUPPLY LABOR TO FABRICATE TOP AND BOTTOM
C/W 1 NOS OF FULL HT CABINET INETRNAL IN WHITE
POLYGAN AND EXTERNAL IN P/LAMINATE C/W TABLE TOP
USING SOLID SURFACE FINISH.
SIZE(600 X 600 X 2400)MM FULL HT CABNINET
SIZE(2000 X 600 X 800)MM LOW CABINET
SIZE(1800 X 320 X 900)MM TOP HUNG CABINET 1 /lot/ lsum/ $6,600.00
SIZE(2310 X 600 X 800)MM LOW CABINET
SIZE(2310 X 320 X 900)MM TOP HUNG CABINET
SIZE(900 X 1 X 600)MM S/STEEL PANEL
18 OPTIONAL ITEM
TO SUPPLY LABOR TO FABRICATE ALUMINIUM DOOR
PANEL WITH FROSTED FILM FOR TOP HUNG CABINET 2 /nos/ $150.00/ $300.00
19 LIVING ROOM TV CABINET
TO SUPPLY LABOR TO FABRICATE LOW CABINET WITH
TIMBER PANEL IN P/LAMINATE PANEL .
SIZE(2400 X 100/500 X 2610)MM 1 /lot/ lsum/ $2,800.00
20 TO SUPPLY LABOR TO LAY WALL COVERING AT MASTER
BED ROOM SIZE(4800 X 2610)MM 1 /lot/ lsum/ $650.00
Gross Total: $33,180.00
7% G.S.T.: $2,322.60
Nett Total: $35,502.60
Edited by CygnusX
Hi CygnusX, Here is the quatotion for carpentry work I got:
Living Room
1 To fabricate & install 13ft(L) low height sette with top opening/solid ply in laminate finish. 2,000.00$
2 To fabricate & install 6ft(L) suspended tv console with drawers with solid ply in laminate finish. 780.00$
3 To fabricate & install 4ft(L) full height display cabinet with solid ply in laminate finish. 1,200.00$
B Kitchen Area
1 To fabricate & install 10ft(L) top and 10ft(L) bottom kitchen cabinet with solid ply in laminate finish. 3,050.00$
2 To fabricate & install 10ft(L) granite worktop with double square profile 45degree cut. (Imperial Black) 1,200.00$
3 To fabricate & install 10ft(L) top and 10ft(L) bottom kitchen cabinet with solid ply in laminate finish. 3,050.00$
4 To fabricate & install 10ft(L) granite worktop with double square profile 45degree cut. (Imperial Black) 1,200.00$
Is this reasonable ?
The kitchen part seems to be expensive to me . Is your TV cabinet with feature wall or just stabd alone?
Hi CygnusX and All, Greetings.
Congrats for your new project. I am also working on quotation for my unit, some items cost about close. Do take a look and comment...
http://www.renotalk.com/forum/index.php?showtopic=46817
Though it has been common that Condo dwellers must pay more, but cannot be everything right? For every item, suggest asking ID/contractor how he can justify the typical 20% to 30% extra, when his workers spend the same amount of time working in the house, whether it's Condo or HDB; In HDB they report to work late, then leave late cos HDB less complaints; In Condo they come late, but leave at 5pm or 6pm, then we have to pay them extra for being late?! I still cracking my head don't know how to bring this up to my contractor nicely, cos he is a nice chap. Or if someone can enlighten us further, tell us more reasons why Condo dwellers must pay more, we'd feel better.
3. 2x13Amp Power Points, our friends in HDB can get as cheap as $55 per unit.
6. Correct me if I am wrong, emulsion paint means it's water-based? Cleaning can be difficult. Can consider Easy-wash type. Nippon Paint's website has some quotations to compare.
http://www.nipponpaint.com.sg/services/professional-painting-services/residential/
13 & 14. I suppose the high price is for building something EXACTLY to your liking. I gave up that idea after knowing the cost. Plan B: Visited some of those mattress/bedframe shops at TradeHub21 (Boon Lay). Saw 2 frames i like, so asked the lady can combine the designs or not, she said can! can! $1400 without bargain. Just briefly the 'new' design has cushioned head board and side board forming a L shape around 2 sides of the king-size mattress, cos i placing the bed to the corner of the room. The mattress sits on a common storage bedframe that opens like car bonnet. Opposite the L board is a 1-feet wide platform with hatches for storage. What I am trying to suggest is, those shops may be able to fabricate what u want, just tell them the dimensions, with drawing even better.
19. As with other items, if have time, try visiting warehouses, may be can find something close to your heart, cheaper. Saturday's newspaper usually has lots of furniture ads. I bought the paper for the ads, not the fictions. If no time then no choice let ID/contractor earn.
Hope this is useful.
Yeah, I am also planning to drop some of the items like display cabinet / study table and buy from some furniture shop !!!
Your kitchen cabinet seems to be 122.22/ft and mine seems to be 151/ft. I have not requested for anything special in those cabinets.
Will talk to ID again.
Living Room
B Kitchen Area
Hi MovingInSoon.
Your living room definitely looks cheaper quote than mine.
You kitchen area, although total length approx 14ft versus your 10ft, but your quote is alot cheaper and states Granite surface rather than solid surface (which could be plywood with Acrylic (like Ikea).
TV cabinet is attached to the feature wall. My request for feature wall is actually just a fake wall to drill and mount LED TV. No fancy design. TV cabinet is on the lower portion to put SCV, DVD, MIO, etc etc. Really simple one.
...feel like a carrot now.
Thanks Folks,
Yes we did consider dropping some because "ideal" costs money.
We are rethinking if some can be purchased "off-the-rack" from furniture shops.
Will consider a visit to Tradehub21. Any other places like this in the east to recommend? (besides Courts)
By the way, Anyone can share what is the market average for...
1/ Per foot run of bedroom wardrobe. Full length. Laminate. No fancy color/design.
2/ Per foot run of kitchen cabinet. $122.22/ft to $151/ft is top hung cabinet and bottom cabinet without top surface? OR only low cabinet?
3/ Per foot run of TV console. Plain with cabinet with simple low cabinets for DVD/MIO/Modem/etc.
3/ What is the additional price for addition of ABS/trim and Blum/Hettich hinges?
4/ What are the grades for laminates for wardrobes? I heard EDLeuro and Jennings are pretty good.
Cheers.
Just see the paint work price already chop carrot, the rest i dont even bothered to see. Everything lsum super hidden.
Thanks durianello.
What would be a reasonable price for repainting approx 1200-1300sqft? No fancy color.No fancy paints. No hacking.
INTERNAL IN WHITE POLYGAN ???
If really use polygan for cabinet internal, choose lighter wood grain design; if choose white, they give you white PVC you also dont know lah.
Thanks. Any other type of internal finishing besides PVC and Polygan?...something better?
