littletiger 0 Report post Posted January 17, 2012 HiJust bought a resale condo and need some advice on renovation. Is the quotation reasonable?Kitchen 3.5mx2.5mtoilet 2.5m*2mA DEMOLITION WORK1 Hacking of kitchen wall tiles 450$ 2 Hacking of common toilet floor tiles 250$ 3 Hacking of common toilet wall tiles 450$ 4 Hacking of wall between yard & toilet 280$ 5 Demolition of door & frame for backyard toilet 120$ 6 Hack existing fittings & accessories in both toilets - vanity / toilet bowl / shower screen 200$ 7 Dismantle / disposal of existing kitchen cabinet 200$ B MASORY WORKS ( SUPPLY & LAY )( TILES UP TO $3 PSF )1 Waterproofing membrane in common bathroom 180$ 2 Non-slip homogeneous floor tiles in common bathroom 480$ 3 Ceramic wall tiles in common bathroom 1,350$ 4 Shower kerb for shower area in common bathroom 150$ 5 Ceramic wall tiles for kitchen 2,200$ 6 Non-slip homogeneous floor tiles for backyard toilet 480$ 7 Make good wall & ceiing item A4 & A5 360$ C WINDOW / GRILLES / GLASS / MIRROR WORKS ( SUPPLY & INSTALL )1 10mm tempered glass shower screen in common toilet ( corner entry ) 650$ 2 10mm tempered glass fixed panel in master toilet 260$ 3 Full height mirror at dining wall 680$ 4 Top hung window with fixed panel in common bathroom 250$ 5 Aluminum grilles in service yard 190$ 6 10mm tempered glass fixed panel in between kitchen & service yard 180$ D CARPENTRY1 Kitchen cabinet with ABS trimming & laminate finish 3,520$ - stainless steel dish drainer - 2 nos. frosted door with laminate frame2 Solid surface kitchen top 1,200$ 3 Suspended vanity with cabinet in common toilet 820$ - abs trimming & laminate finish - Solid surface table top - full height mirror4 Vanity with cabinet in master toilet 680$ - abs trimming & laminate finish - Solid surface table top5 Replace 18 nos. wardrobe handle 120$ 6 Suspended tv console with feature wall in laminate finish 6ft 1,800$ E PAINTING WORKS1 Painting of whole house wall & ceiling 1,380$ 2 Varnish all doors / frames 560$ F PLUMBING WORKS1 Supply and lay outlet piping for kitchen sink 80$ 2 Supply and lay outlet piping for 2 toilets basin 120$ 3 Labour to install kitchen sink & tap 180$ 4 Labour to install 2 toilets mirror accessories 90$ 5 Labour to install 1 no. storage water heater 150$ 6 Supply labour to install 2 sets of WC 200$ 7 Supply labour to install 2 sets of water basins and taps 160$ G GENERAL1 Polising of existing marble floor in living / dining hall 580$ 2 Supply and lay corrugated cardboard to protect existing flooring 180$ 3 Acid wash and general cleaning 250$ 4 Disposal of renovation debris 300$ 5 Haulage services 350$ H ELECTRICAL WORKS ( estimate )1 Add 1 no. light point 35$ x 5 175$ 2 Install 1 no. light ( normal ceiling or L-box ) 10$ x 10 100$ 3 Install 1 no. hanging light 45$ x4 Add / shift 1 no. single socket power outlet 50$ x5 Add / shift 1 no. double socket power outlet 60$ x6 Add 1 no. scv point 120$ xI OPTIONAL ITEM1 Change new piping in common toilet ( concealed ) 750$ Total 23,190$ Share this post Link to post Share on other sites
Christakis 0 Report post Posted January 18, 2012 Hi, what is the total length of yr kitchen cabinets? Share this post Link to post Share on other sites
littletiger 0 Report post Posted January 18, 2012 Hi Christakis, 1 bottom cabinet 3.3m L * 0.7m H 1 bottom cabinet 1.4m L * 0.7m H 1 Wall cabinet 3.3m L * 0.7m H 1 Wall cabinet 1.4 L * 0.7m HAppreciate your view. Thanks!!! Share this post Link to post Share on other sites
EoneKhaled 0 Report post Posted February 27, 2012 From whice ID? Share this post Link to post Share on other sites
beemer75 0 Report post Posted March 1, 2012 TS,dun mind if I ride on your thread. If you mind I wld gladly move out. Just trying to save opening a new thread.Hi AllGot a quote for the repair/reno of 2 toilets. Wonder if its reasonable. Tks2nd Storey toilet:To hack existing bathtub, basin, floor tiles with dispose. $500.00To apply water proofing membrane on the floor. 300.00To supply and lay new wall and floor tiles. $3500.00To construct new ceiling board. $300.00To supply labour to install toilet bowl and basin. $200.00 To supply and install 1 set of tamper glass shower screen. $800.003rd Storey toilet:To hack existing bathtub, basin, floor tiles with dispose. $500.00To apply water proofing membrane on the floor. $300.00To supply and lay new wall and floor tiles. $3500.00To supply labour to install toilet bowl and basin. $200.00 To supply and install 1 set of tamper glass shower screen. $800.00(Optional)Additional item:To hack existing wall tiles with dispose. (1 x toilet) $500.00To replace existing pipe. (conceal) (1 x toilet) $900.00 Share this post Link to post Share on other sites
jadens28 1 Report post Posted March 1, 2012 hi,no sure the size of your toilet. But usually the cost of laying new tile HDB toilet flooring include water proofing should be around the range of $450 to $600.And the shower screen a bit expensive, should be around the range of $400 to $600 for 10mm tempered glass.If you intereted i can pm you my contractor contact.Try to get more quote to compare.Cheers!!TS,dun mind if I ride on your thread. If you mind I wld gladly move out. Just trying to save opening a new thread.Hi AllGot a quote for the repair/reno of 2 toilets. Wonder if its reasonable. Tks2nd Storey toilet:To hack existing bathtub, basin, floor tiles with dispose. $500.00To apply water proofing membrane on the floor. 300.00To supply and lay new wall and floor tiles. $3500.00To construct new ceiling board. $300.00To supply labour to install toilet bowl and basin. $200.00 To supply and install 1 set of tamper glass shower screen. $800.003rd Storey toilet:To hack existing bathtub, basin, floor tiles with dispose. $500.00To apply water proofing membrane on the floor. $300.00To supply and lay new wall and floor tiles. $3500.00To supply labour to install toilet bowl and basin. $200.00 To supply and install 1 set of tamper glass shower screen. $800.00(Optional)Additional item:To hack existing wall tiles with dispose. (1 x toilet) $500.00To replace existing pipe. (conceal) (1 x toilet) $900.00 Share this post Link to post Share on other sites
beemer75 0 Report post Posted March 2, 2012 Hi Jadens,Sure appreciate that tks.hi,no sure the size of your toilet. But usually the cost of laying new tile HDB toilet flooring include water proofing should be around the range of $450 to $600.And the shower screen a bit expensive, should be around the range of $400 to $600 for 10mm tempered glass.If you intereted i can pm you my contractor contact.Try to get more quote to compare.Cheers!! Share this post Link to post Share on other sites
May_dream1 14 Report post Posted March 2, 2012 hi,no sure the size of your toilet. But usually the cost of laying new tile HDB toilet flooring include water proofing should be around the range of $450 to $600.And the shower screen a bit expensive, should be around the range of $400 to $600 for 10mm tempered glass.If you intereted i can pm you my contractor contact.Try to get more quote to compare.Cheers!!if its private property of bungalows, i am sure the toilets are big. And the price of the tiles psf are not stated. If choose marble which cost $20-$50 psf, having toilet reno costing $3000 is quite normal. Share this post Link to post Share on other sites
jadens28 1 Report post Posted March 2, 2012 Yup agree with that. Must check on the material to be use.if its private property of bungalows, i am sure the toilets are big. And the price of the tiles psf are not stated. If choose marble which cost $20-$50 psf, having toilet reno costing $3000 is quite normal. Share this post Link to post Share on other sites
