kennynaz
Renovation Quote
Hi fellow RT members.
Pls comment if this quote is reasonable. Thanks!
Dear Sir,
Thank you for your enquiry, we have the pleasure to quote you the best price as follows.
Wet Works
1. To supply and lay 300mm x 300mm homogeneous floor tiles at kitchen. ( S$ 1,000 )
2. To supply and lay homogeneous floor tiles at 2 bathrooms. ( S$ 900 )
3. To supply and lay ceramic wall tiles at 2 bathrooms to ceiling height. ( S$ 2,900 )
4. To supply and construct cabinet base, fridge base and washing machine base. ( S$ 320 )
5. To supply and lay waterproofing at 2 bathroom flooring. ( S$ 300 )
6. To supply labor and construct shower kerb at common bathrooms. ( S$ 120 )
Total : S$ 5,540
Plumbing Works
1. To replace kitchen and 2 bathroom piping to stainless steel pipe. ( S$ 750 )
2. To supply and install hot water piping for 2 no shower. ( S$ 550 )
3. To supply and install 1 no storage heater, 2 no rain shower, 2 no mixer, tap and all bathroom accessories. ( S$ 1,280 )
4. To supply and lay outlet pipe for kitchen sink and washing machine. ( S$ 100 )
5. To supply and install 2 no sitting bowl and 2 face basin. ( S$ 980 )
6. To supply and construct long bath at master bathroom c/w 10mm clear tempered glass fixed panel. ( S$ 1,300 )
Total : S$ 2,050
Carpentry Works
1. To supply and install kitchen cabinet c/w abs trimming, handle, 2 no glass panel in laminate finishing 30’. ( S$ 3,300 )
2. To supply and install dish rack c/w glass panel and hydraulic hinge. ( S$ 180 )
3. To supply and install solid surface top at kitchen cabinet 15’. ( S$ 1,050 )
Total : S$ 4,530
Misc Works
1. To supply and lay laminate flooring **** and 3 bedroom c/w skirting. ( S$ 3,300 )
2. To supply and install 10mm clear tempered glass shower screen at common bathroom c/w fixed panel and swing door. ( S$ 550 )
3. To supply and install 2 no alum. Bi-fold door at 2 bathrooms. ( S$ 440 )
4. To supply and install wrought iron gate. ( S$ 520 )
5. To paint whole house using ICI. ( S$ 1,250 )
Total : S$ 6,060
Hacking And Haulage Works
1. To hack off existing floor tiles at kitchen and 2 bathrooms. ( S$ 700 )
3. To hack off existing wall tiles at 2 bathrooms. ( S$ 600 )
4. To dismantle existing kitchen cabinet. ( S$ 250 )
5. To hack off existing skirting and make smooth finishing **** and 3 bedroom. ( S$ 550 )
6. To load up material and clear debris from site. ( S$ 450 )
Total : S$ 2,550
We Trust That You Will Find Our Offer Acceptable To You And We Are Looking Forward To Receive Your Order In Due Course.
here was the quote which i got from my contractor (highlighted in red).
only a slight different.
if you are confortable with him, maybe can engage him.
Cheers!
Dear Sir,
Wet Works
2. To supply and lay homogeneous floor tiles at 2 bathrooms. ( S$ 900 ) ($1,000 include waterproofing)
4. To supply and construct cabinet base, fridge base and washing machine base. ( S$ 320 ) ($250 for cabinet & fridge base)
5. To supply and lay waterproofing at 2 bathroom flooring. ( S$ 300 ) ($0)
6. To supply labor and construct shower kerb at common bathrooms. ( S$ 120 ) ($90)
Total : S$ 5,540
Plumbing Works
1. To replace kitchen and 2 bathroom piping to stainless steel pipe. ( S$ 750 ) ($750)
2. To supply and install hot water piping for 2 no shower. ( S$ 550 ) ($360)
Total : S$ 2,050
Carpentry Works
1. To supply and install kitchen cabinet c/w abs trimming, handle, 2 no glass panel in laminate finishing 30’. ( S$ 3,300 ) ($110 per ft include 1 no. dish rach & 1 no. glass panel with wooden laminate finishing frame )
2. To supply and install dish rack c/w glass panel and hydraulic hinge. ( S$ 180 ) ($0)
3. To supply and install solid surface top at kitchen cabinet 15’. ( S$ 1,050 ) ($1050)
Total : S$ 4,530
Misc Works
1. To supply and lay laminate flooring **** and 3 bedroom c/w skirting. ( S$ 3,300 ) (Dunno your floor area can't compare)
2. To supply and install 10mm clear tempered glass shower screen at common bathroom c/w fixed panel and swing door. ( S$ 550 ) ($380)
3. To supply and install 2 no alum. Bi-fold door at 2 bathrooms. ( S$ 440 ) ($200 for 1 no. of 6 panel alum. bi-fold door)
Total : S$ 6,060
Total : S$ 2,550
Dear Sir,
Wet Works
1. To supply and lay 300mm x 300mm homogeneous floor tiles at kitchen. ( S$ 1,000 ) kitchen space bout 120 -130 sqft?
2. To supply and lay homogeneous floor tiles at 2 bathrooms. ( S$ 900 ) 2 bathroom floor around 650-700, 900 should include water proofing?
3. To supply and lay ceramic wall tiles at 2 bathrooms to ceiling height. ( S$ 2,900 ) sound gd for 2 bathroom wall, tiles should below 3dollar
4. To supply and construct cabinet base, fridge base and washing machine base. ( S$ 320 ) sound ok
5. To supply and lay waterproofing at 2 bathroom flooring. ( S$ 300 ) ?
6. To supply labor and construct shower kerb at common bathrooms. ( S$ 120 ) sound ok
Total : S$ 5,540
Plumbing Works
1. To replace kitchen and 2 bathroom piping to stainless steel pipe. ( S$ 750 ) sound ok to me
2. To supply and install hot water piping for 2 no shower. ( S$ 550 ) sound ok to me
3. To supply and install 1 no storage heater, 2 no rain shower, 2 no mixer, tap and all bathroom accessories. ( S$ 1,280 )sound gd
4. To supply and lay outlet pipe for kitchen sink and washing machine. ( S$ 100 ) should be include in no1
5. To supply and install 2 no sitting bowl and 2 face basin. ( S$ 980 ) hmmm can be cheaper
6. To supply and construct long bath at master bathroom c/w 10mm clear tempered glass fixed panel. ( S$ 1,300 ) long bath include will be a gd catch
Total : S$ 2,050 ??? add up should be 4960 ba
Carpentry Works
1. To supply and install kitchen cabinet c/w abs trimming, handle, 2 no glass panel in laminate finishing 30’. ( S$ 3,300 ) market prices ba. have to see workmanship
3. To supply and install solid surface top at kitchen cabinet 15’. ( S$ 1,050 ) should be local market brand, prob in 2-3 years time, after all wat can u ask for at this prices
Total : S$ 4,530
Misc Works
1. To supply and lay laminate flooring **** and 3 bedroom c/w skirting. ( S$ 3,300 ) total sqft? 900-1000? what brand ?
2. To supply and install 10mm clear tempered glass shower screen at common bathroom c/w fixed panel and swing door. ( S$ 550 ) sound gd
3. To supply and install 2 no alum. Bi-fold door at 2 bathrooms. ( S$ 440 ) reasonable
4. To supply and install wrought iron gate. ( S$ 520 ) reasonable
5. To paint whole house using ICI. ( S$ 1,250 )4room flats?
Total : S$ 6,060
1. To hack off existing floor tiles at kitchen and 2 bathrooms. ( S$ 700 )reasonable
3. To hack off existing wall tiles at 2 bathrooms. ( S$ 600 )ok
4. To dismantle existing kitchen cabinet. ( S$ 250 ) around 150
5. To hack off existing skirting and make smooth finishing **** and 3 bedroom. ( S$ 550 ) around 200
6. To load up material and clear debris from site. ( S$ 450 ) around 200
Total : S$ 2,550 sound exp for just hacking of bathroom and kitchen plus skirting for whole unit.
hope it help, happy renov
