getzski
Single's Home In Bedok Res
**** happens....did a washing machine test to test the water flow inbound and outbound. as the washing machine came towards the end of the spinning cycle, it shook violently, and the dryer which is stacked on top came crashing to the ground. check out the "Scar" below.
called customer service and they suspect that the violent spinning is due to a transport bracket that is still afix to the washing machine, resulting in the accident.
oohh.... must be heartache for you.... so they will exchange a new dryer for you since its their fault?
What brand of washing machine you are using?
I stay ground floor,there are some pipings jutting out of the ground just outside my toilet windows. Those are the pipes you guys referring to?
Water pressure can adjust from there?
my resale 42yrs old.. antique!
:bow:
can try. it should be a nut that can be adjust via spanner. someone need to be in the house when you adjust though so that they can take you when you got the right one.
when you find it....remember to do a paint marking on it so you will know next time. :sport-smiley-004:
Yours at toa payoh.... a lot of those there are quite old...
mine is not newest flat... so i get to enjoy this flaw too... hhahahaah...
so many lights? won't it be too much??
yup. too much. switch on one light (3 bulbs) already very bright. will try to swop with smaller wattage bulbs (from 19W to 9W) and see how it goes.
EF.
no need to replace a whole dryer. after that incident, then i realise it is basically a steel/mdf board casing, a steel drum, and a top control panel. it is likely they replace only the control panel. they will come tomorrow. let me "sweet talk" my way into a free replacement.
EF.
ya loh, don't waste the electricity.... better change to lower watts. do you cook often?
if you cannot sweet talk them, get yr gf to do it lah. maybe she can do a better job. Since you didn't read my tblog, you didn't know they named me as the "teah queen of renotalk". :bangwall:
tried the 9w warm.....don't like. i think i still prefer the overwhelming lights.
life savior arrived....need the fan and air cleaner. due to aircon still non-operational yet, and the amount of dust the mrt construction is generating.
rice cooker, blender, garment steamer, jet turbine fan, air purifier, tower fan, humidifier, induction cooker, wmf pot. all for the princely amount of 728.
hmmm...same guy hugging different gals in the pics.
all from EUROACE. i'm a fan of buying under one roof. lol.
does it mean that you also have 4 gf? :jawdrop:
