keyswz
Changing Colour Of Laminated Door
Hi all,
How can this be done?
Must it be via removing the original laminate and pasting a new one?
Can it be painted over?
Also, if I have nyatoh wood door (think colour is rosewood), how can I change its colour to a darker shade like walnut while retaining its wood grains?
Thanks in advance.
Edited by keyswz
for old laminates.... this can be done but it's alot of work....
painting over it is not really ideal because the paint would most probably bloge...
Nytoh wood door painting over it not an issue...
you need to see if the existing paint has already covered most of the wood grains...
if yes then you need to sand it down with a sander....
if not then you can just paint over it.....
Hi all,
Thanks in advance.
Ben, thanks for the reply.
Hmm, I thought painting over will cover the wood grains? The option I thought I had was to stain it, but effect will not be good as the door had been stained with another colour.
