jekky
Is This Quotation Expensive?
Demolition Works & General Services ($1100)
01. Provide labour to hack off existing wardrobe at master bedroom.
02. Provide labour to hack off existing wall between dining and living area.
03. Provide labour to hack off whole house skirting between dining and living area.
04. Provide labour to dismantle existing door & door frame at master bedroom.
05. Provide labour to hack off existing wall as a new entrance at master bedroom.
06. Disposal of renovation debris
07. Disposal of wood debris
08. Haulage Service
Masonry Works
01. Supply materials & labour to seal up existing entrance with hollow block, inclusive of cement screed at master bedroom. $450
02. Supply materials & labour to touch up damages on affected area after wall hacking at master bedroom. $200
03. Supply materials & labour to touch up damages on affected area after wall hacking **** dining area. $200
04. Supply materials & labour to touch up damages on affected area after hacking skirting for whole house. $450
Partition Works
01. Supply materials & labour to install partition frame as sliding door panel support at master bedroom. $550
B.T.W., ask 2 IDs, one give 1 year warranty and the other give 5 year warranty. Is 5 year warranty definitely better and means better workmanship? Thanks a lot!
Door / Timber / Laminate Works
01. Supply materials & labour to overlay vinyl tile with skirting at living dining. $1875
02. Supply materials & labour to overlay vinyl tile with skirting at balcony. $380
03. Supply materials & labour to overlay laminate flooring with skirting at study room. $550
03. Supply materials & labour to overlay laminate flooring with skirting at master bedroom. $720
04. Supply materials & labour to overlay laminate flooring with skirting at bedroom 2. $550
05. Supply materials & labour to overlay laminate flooring with skirting at bedroom 3. $550
06. Supply materials & labour to reinstall existing door at master bedroom. $60.00
07. Supply materials & labour to install wooden door frame at master bedroom new entrance. $250.00
Miscellaneous
01. Supply materials & labour to paint whole house using NIPPON emulsion paint. $1500
02. Supply materials & labour to lay cardboard protection at affected area. $180
03. Chemical washing for whole house to remove stains. $200
04. General Cleaning for whole house upon completion. FOC
Budgetary Carpentry Quotation Base on Max 2 colour laminate.
( Prices are subjected to change at final design & material stage )
Living/Dining/Foyer
Design, fabricate & install TV console in laminate and PVC carcass finish.
Size : L 2400mm $1440
Design, fabricate & install SERIES SUPPLY as a divider in spray paint finish between living and passage way area.
Size : L 2400mm $2600
Design, fabricate & install open shlelving cum display cabinet in laminate and colour PVC carcass finish.
Size : L 600mm $900
Master Bedroom
Design, fabricate & install pole system wardrobe c/w aluminium sliding door panel and dressing table.
Size: L 3300mm $2850
Edited by jekky
