sohnice
3 Room Hdb
can u pm me is Panasonic inverter system 3 quiet? any noisy?
Hi Dean, my panasonic inverter system 3 is very quiet. When the room is cool, the compressor will stop running. That tells why my PUB bills is so low compare to my previous house. I would highly recommend it. :good:
U set temperature to 16? I no regret getting Panasonic inverter. It very quiet. I worry upper level throw wood at my outdoor compressor unit. Can put aluminum paper or card board on top of outdoor compressor unit. If put will catch fire Bo?
I set temp to 26 very cold liao, where you stay? Why will upper level throw wood down? Is it rubbish dump very near your unit? :sport-smiley-004: Lucky i staying highest floor, only i can throw things down :notti: You don't put card board lor, i would suggest you to put aluminium foil that they use to put behind the stove to protect oil from spilling on the wall.
at first i set to 16 i don't feel cold leh after a while i set back to 24..very cold. can see ur aircon trunking?
All my air-con piping has been box up. If major servicing will have to dismantle the partition. :bangwall:
Edited by sohnice
Hi Sohnice,
Your placeis so nice and beautiful.
Can pm me your id/contractor's contact? And your quotation if you don't mind.
By the way, where did you get your digital eyepiece? Can it record the view outside? For how many hours?
Thanks a lot.
