emale
How To Remove White Marks On Black Kitchen Flooring
I have this really irritating problem.
White spots/marks keep re-appearing on my black slate kitchen flooring. It usually looks ok after mopping/when wet, but when it dries up, the white spots keep re-appearing.
Any advise on how to solve this problem? :unsure:
You can try touch up using black paint marker and apply a layer of thin lacquer over it.
U can use color enchancer.
Maybe u can contact CK @ 9369 9469, he has this product and he can advise u on this.
Hi emale, which solution did you choose? I've a similar problem, which i suspect my contractor didn't do a good clean up job. If the methods work for you, i would like to try too. Pls share. Tks.
