zenith9
Renovation Cost (Pls Help!)
All below items are for the master bedroom toilet. Total cost at $6,410.
I heard the normal rate is around 3.5k to 4k. Need some advise from you guys. Thanks in advance.
01.Supply/construct non-slip floor tiles for master toilet (<$3psf) - $480
02.Waterproofing to be carried out for master toilet - $200
03.Supply/construct 2 tone full height wall tiles for master toilet (<$3psf) - $1,380
04.Supply/replace new stainless steel piping for master toilet basin and conceal drain pipe for master toilet basin - $350
05.Supply labour to install all toilet accessories - $250
06.Supply/construct L-sharp shower kerbs with matching tile for master toilet - $240
07.Supply/install solid timber door c/w lock set and varnishing for master toilet entrance - $480
08.Master toilet: Supply/install aluminium/frame Acrylic shower screen for master toilet (L-sharp) - $580
09.Master toilet: Supply/install laminated suspended cabinet below vanity - $480
10.Master toilet: Supply/install wall to wall solid surface vanity (exclude basin) - $450
11.Hacking of existing floor tiles, wall tile, toilet bowl and basin for master toilet - $580
12.Debris removal services to be carried out - $280
13.Haulage of sand to be carried out - $380
14.Supply/lay corrugated board to protect existing flooring (include disposal) - $180
Edited by zenith9
just for master toilet? then i think it is expensive in my opinion
I thought so too. Normal rate is around 3.5k to 4.5k right?
Even if I remove the vanity box below the basin, it still cost me about 5.5k...
