Nellynutt 0 Report post Posted November 3, 2011 Hi all,Stumbled these problem during demolition, can this beam be hacked? Thanks in advance Share this post Link to post Share on other sites
therat 18 Report post Posted November 3, 2011 did your contractor get HDB approval for any hacking?Is this inside the DWG that they submit to the HDB for approval?If all the above, NO.Then U need to pray super hardhttp://askhdb.hdb.gov.sg/Home/Hybrid/Themes/HDB/view-results.asp?mesid=5654673&iscfp=&selectedcategory=&from=ask&folderid=&projectid=7875909&reaskpage=answer%2Easp&recordquestion=&returnurl= Q: Do I need a permit for hacking of walls?[ Living in HDB Flats > HDB Renovation Guidelines > Renovation Works ] A:Yes, you need to apply for a permit from HDB which must be endorsed by a Qualified Person (QP) or Professional Engineer (PE).Please note that you are only allowed to hack/demolish non-load bearing reinforced concrete walls. You may not hack/demolish load bearing walls. Share this post Link to post Share on other sites
therat 18 Report post Posted November 3, 2011 oh!BTW, HDB don't buy the story if the owner say.. I don't know.. my contractor say can hack Share this post Link to post Share on other sites
Nellynutt 0 Report post Posted November 3, 2011 (edited) y pray super hard?We had all the required permits.. just not feel safe to continue to hack the area Edited November 3, 2011 by Nellynutt Share this post Link to post Share on other sites
therat 18 Report post Posted November 3, 2011 If you had HDB approval to hack the wall. mean it is safe to hack.If you had doubt, best contact HDB. Share this post Link to post Share on other sites
Lauer 15 Report post Posted November 3, 2011 Hi all,Stumbled these problem during demolition, can this beam be hacked? Thanks in advanceDear Nellynut,Better consult your QP/PE before continuing. The column appears to be RC to me.It is no a matter of having the permit or not, but safety. Share this post Link to post Share on other sites
Nellynutt 0 Report post Posted November 5, 2011 Dear Nellynut,Better consult your QP/PE before continuing. The column appears to be RC to me.It is no a matter of having the permit or not, but safety.Hi Lauer,Thank you for your concern, based on our floor plan there is no black block/beam at that area. The TO also shocked when i told her... in the end, we decided not to hack = no open concept = save $$$ So I Can say this Case Closed Share this post Link to post Share on other sites
Synchron 0 Report post Posted November 17, 2011 It can be hacked, its a prefabbed wall.. have to go through PE though. I bet the person who send permit to the HDB did not note that he will be hacking of the wall. Share this post Link to post Share on other sites
