sgsam
Our First Home Reno Project
Hi all,
We recently bought a resale private apartment and are about to embark on our home reno project before we move in. The place is pretty old and in need of an upgrade. Wifey and I have seen a few IDs and are close to settling on one (hopefully in the next few days). I will provide the quote in the next entry and perhaps can get some feedback from more experienced folks on whether the quote looks reasonable.
Unfortunately, I don't have a floor plan to share just yet as the previous owner's weren't able to provide one. Any ideas on where I can get one for a private resale apartment?
As promised, this is the quote provided by one of the IDs we have approached. Would appreciate if those more experienced in the process can comment on whether this looks reasonable or are we being overcharged?
HACKING WORK - $4200
Hack off existing kitchen flooring & kitchen cabinet
Hack off existing kitchen sink & stove support
Hack off existing kitchen toilet door
Supply labour to remove existing tank heater at kitchen toilet
Haulage fee & sand fee
Hack off existing common toilet kerb & 2 toilet bowl & 1 basin
Hack off existing kitchen door frame
Hack off existing 3 rooms parquet flooring
Hack off existing living & dining ceramic flooring and skirting
Hack off existing 3ft internal steps
Hack of 6" wall to extend kitchen entrance
TILING WORK - $12,100
Supply & lay kitchen flooring c/w homogeneous tiles (30 x 30)
Supply & lay waterproofing for kitchen floor
Construct fridge, washing machine and cabinet base c/w tiles finish
Supply & lay kitchen toilet flooring c/w homogeneous tiles (30 x 30)
Construct 'L' shape shower kerb at common toilet
Supply & overlay common toilet shower area flooring
Supply & lay homogeneous tiles (60 x 60) ****, dining and 3 bedrooms c/w white tiles skirting
Construct a low wall at in between living to dining area (36' x 33")
To construct 6" wall to extend kitchen entrance wall
Supply & overlay kitchen yard flooring c/w homogeneous tiles (60 x 60)
Supply & overlay kitchen yard toilet c/w homogeneous tiles (30 x 30)
Supply & overlay back store room c/w homogeneous tiles (30 x 30)
Construct a wall at kitchen new store room
PLUMBING WORKS - $2,560
Supply & install instant heater at common toilet
Supply & install 3 nos hand shower spray for 3 toilets
Supply labour to position kitchen sink piping & yard sink
Supply & install square basin c/w tap at common toilet
Supply & install 2 toilet bowl for common & master toilet
Supply & install master toilet basin waste trap
Supply labour to install rain shower mixer set
Supply & install double bow stainless steel kitchen sink c/w tap
Supply & install single bowl stainless steel yard sink c/w tap
DOOR & WINDOW - $2130
Supply & install bi-fold door at kitchen toilet
Supply & install 6 nos door lock set
Supply & install roller for living hall sliding door
Supply & install tempered glass shower screen at common toilet ('L' shape)
Supply & install wooden glass sliding door at kitchen entrance
CARPENTRY WORKS - $13,430
Built in kitchen cabinet c/w laminated finish & ABS trimming and soft close door (35ft)
Supply & install granite kitchen table top (19ft)
Built in low basin cabinet at common toilet (3ft)
Built in sliding wardrobe at room (1) c/w laminated finish
Built in sliding wardrobe at room (2) c/w laminated finish
Built in sliding wardrobe at master room c/w laminated finish (8ft)
Built in top cabinet & door for new kitchen store room
Built in low cabinet at kitchen yard area (3ft)
Built in 4 pcs pillar divider in between living to dining
OTHER - $12,000
Supply & reinstall new wire DB box
Painting the whole house include 6 doors
Acid washing & clear the whole house
Supply & install 1 to 1 air-con (2400 BTU) Mitsubishi Inverter **** hall
Supply & install 1 to 3 air con for 3 room (9000 BTU) Mitsubishi inverter
Supply & install 10 nos living points
Supply labour to re-conceal living hall light switch
Supply & install ceiling fan point and install ceiling fan
Supply & install 'L' shape metal rack (3 layer) and c/w wooden shelves at kitchen store room
Built in false ceiling at kitchen
To box up top kitchen ('L' shape)
Supply & install sliding tempered glass shower screen at master room
To waterproofing and make good at store room window
Supply & lay tempered glass blacking in between kitchen cabinet (14ft)
TOTAL - $46,420
Welcome... your MCST should be able to provide you your floorplan.
I am a total newbie....MCST? is that the management committee?
I got some photos of the current place...
From the living room, looking towards dining area and doors to bedrooms (wifey really hates the door colour!)
The living room
Master bedroom (planning to change the flooring and the window aircon)
Only got these photos for the moment. None of the kitchen (which needs the most work). Will upload when I get time later.
Hi sgsam
Welcome to renotalk and good luck with your reno.
I'm not sure about the prices, best get the ones who have more info to comment (coz the previous 3 apartments I renovated were brand new condo's). Your condo management should be able to give you a copy of the floor plan, easier to plan around and ask for comments that way.
Hi sgsam
Thanks patsy. I will check with condo mgmt. hope to get more feedback on the quote from other members. keep us posted on your progress and i'll be sure to update on our progress as we get along, so do check back in! :yamseng:
you can apply the floor plan thru BCA also.
http://www.bca.gov.sg/BuildingInfoPlans/request_copy_plans.html
1.Apply online $20 plus within 5 working days they will reply you.
2.Once you get the reply from BCA , you need to go down personally to BCA at maxwell to choose the floorplan/drawings you want . abt $25 per copy. best is to get your ID to go down with you.
3. Need to show BCA your option to purchase to prove that you are the owner.
I got problem getting my floor plan with the previous owner and MCST . hope this help ..
Hi Hin,
That is great information. Thanks v much. I'll see if I have any luck with the building management. If not, I'll be down to the BCA.
Off to see tiles @ Hafary tomorrow. I have read from others that this is the place to go for good tiles at a reasonable price. Hopefully be able to get some samples/pics to give a sense of what we are looking to do.
Are there any other places we should check out for tile selection?
Wifey and I were discussing the clothesline yesterday and given the high ceiling we have, I got to think of something that is easy to hang the clothes - I was thinking something retractable. I came across this company, Ezzi Living, and their automated (EZ Bella) and manual (EZ Lift) retractable clotheslines.
You can check out the pics and product demo video on their website - www.ezziliving.biz
I need to take some measurements to see whether it will work for our laundry.
Has anybody had installed/used either of these?
I noticed that mrspiglet has used another of their products. You can see it on her t-blog (http://www.renotalk.com/forum/index.php?showtopic=18317&st=800)
