snoopy2006
Is This Reasonable ?
Got an quotation from 1 ID company for my 5 room point block flat.
Is this reasonable? Any other things i should take note or i can reduce further?
Professional Services
Design Consultation & Space Planing Complimentary
Design Proposal & Perspective Drawing Complimentary
Selection Of Colour ,Material & Accessories Complimentary
Site Co-ordination & Supervision Complimentary
Decorative Advice Complimentary
5 Years Warranty With Guaranteed After Sales Service Complimentary
Hacking Works :
Hacking of existing floor tiles at 2 bathrooms & kitchen. inclusive
Hacking of existing wall tiles at 2 bathrooms & kitchen . inclusive
Dismantle & dispose existing toilet bowl & basin at 2 bathrooms. inclusive
Dismantle of existing wall panel at kitchen entrance inclusive
Dismantle & dispose existing toilet door at bathrooms. inclusive
Dismantle existing kitchen cabinet inclusive
Hacking of existing floor skirting at 3 bedroom inclusive
Lump Sum: $3,000.00
Masonry/Tiling Works
Common toilet
Supply material & lay cement screeding at common bathroom wall inclusive
Supply & install 300mm x 600mm glossy design / 2 tones ceramic tiles at common bathroom $1,320.00
wall till ceiling height.
> selection of tiles up to $2.6psf
> excluding : Borders/Special Tiles
> est.220sqft inclusive of wastages
Laying of 2-Step K-11/104 Water Proofing Membrane) at common bathroom $150.00
Supply material & lay cement screeding at common bathroom floor inclusive
Supply & lay 300mm x 300mm heavy duty non-slip homogenous floor tiles at common $480.00
bathroom
> selection of tiles up to $3.00 psf
Master toilet
Supply material & lay cement screeding at master bathroom wall inclusive
Supply & install 300mm x 600mm glossy design / 2 tones ceramic tiles at master bathroom $1,320.00
> est.210sqft inclusive of wastages
Laying of 2-Step K-11/104 Water Proofing Membrane) at master bathroom wall $150.00
Supply material & lay cement screeding at master bathroom floor inclusive
Supply & lay 300mm x 300mm heavy duty non-slip homogenous floor tiles at master bathroom $480.00
floor.
Kitchen
Supply material & lay cement screeding at kitchen wall inclusive
Supply & install 300mm x 600mm glossy design / 2 tones ceramic tiles at kitchen $2,880.00
> est.480sqft inclusive of wastages
Laying of 2-Step K-11/104 Water Proofing Membrane) at kitchen floor $250.00
Supply material & lay cement screeding at kitchen floor inclusive
Supply & lay 300mm x 600mm heavy duty non-slip homogenous floor tiles at kitchen $1,000.00
floor.
Living
Supply material & lay cement screeding **** floor $570.00
Supply & lay 600mm x 600mm polised glossy homogenous floor tiles **** floor $2,855.00
> est.571sqft inclusive of wastages
Supply & lay 600mm x 600mm polised glossy homogenous floor tiles **** skirting $300.00
Supply & construct 50mm cement mortar kitchen cabinet base finish with side tiling work. $300.00
Supply & construct 50mm cement mortar washing machine base finish with full tiling work. $90.00
Supply & construct 50mm cement mortar fridge base finish with full tiling work. $90.00
Supply & construct 2 no of shower kerb at master bathroom . $200.00
Supply labour & material to make good at damage area $200.00
Supply & install 1 set of stainless steel flat rubbish chute $180.00
Carpentry works
Design,fabricate & install (L)28ft kitchen cabinet in solid-ply finish with high grade $2,800.00
AMIRA 2011 laminate comes with:
> Abs trimming casement doors FOC
>01 no.s of 2 tier dish drainer FOC
> 01 no.s of cultery tray FOC
> 01 panel aluminium frame sand-blasted glass with hydraulic hinge FOC
Design,fabricate & install est. (L)5ft breakfast table in solid-ply finish with high grade $450.00
AMIRA 2011 laminate ****
Design,fabricate & install est.(L)2.5ft suspended vanity cabinet in solid-ply finish with $300.00
high grade AMIRA 2011 laminate at master bathroom
high grade AMIRA 2011 laminate at common bathroom
Design,fabricate & install est. (L)10ft Full height built-in wardrobe & tv feature wall & $2,600.00
tv console in solid-ply finish with high grade AMIRA 2011laminate casement door
at master bedroom
Design,fabricate & install est. (L)6ft Full height cabinet in solid-ply finish with high grade $1,260.00
AMIRA 2011 laminate casement door at kitchen
Design,fabricate & install est. (L)4ft Full height shoe cabinet in solid-ply finish with high grade $840.00
AMIRA 2011 laminate casement door at foyer area
Door Works
Supply & install 2 nos. of design aluminium Bi-fold door c/w acrylic panel $200.00
Plumbing Works
Supply & install stainless steel cold & hot water piping for whole unit $1,000.00
Supply labour to install 1 set of Gallon Heater $120.00
Supply labour to install 2 set washing basin & taps $110.00
Supply labour to install 1 set of Kitchen Sink c/w Tap $90.00
Supply labour to install 2 sets of bathroom accessories $50.00
Supply labour to install 2 nos toilet bowl $140.00
Supply labour to install 2 nos spray gun $50.00
Laying of concealed 2'' drainage pipe for kitchen sink FOC
Laying of concealed 2'' drainage pipe for washing basin common bathroom FOC
Painting Works
Painting of whole unit using Nippon Original Paint: $1,200.00
> all internal wall & ceiling with NIPPON vinilex 5000 Paint
> all pvc electrical casing NIPPON vinilex 5000 Paint inclusive
> all pvc pipe with NIPPON Bodelac 9000 Paint inclusive
Painting of main gate using Nippon Original Paint inclusive
Glass Works
Fabricate & install 1 set of est.(L)1500mm x (H)1800mm Frameless 10mm Clear Tempered Glass $450.00
1 set fixed panel 1 set swing door at master bathroom
> 10mm(thk) Clear Glass
Fabricate & install 1 set of est.(L)1700mm x (H)1800mm Frameless 10mm Clear Tempered Glass $450.00
1 set fixed panel 1 set swing door at common bathroom
Fabricate & install 1 set of est.(L)900mm x (H)2100mm Frameless 10mm frosted Tempered Glass $550.00
Fabricate & install 2 set of est.(L)2400mm x (H)700mm Frameless 6mm White Tempered Glass $800.00
backing
Electrical Works
Supply labour to install 14 lighting point at dining $490.00
Supply labour to install 12 lighting point at Guest room & kids room $420.00
Supply labour to install 18 lighting point **** $630.00
Supply labour to install 3 lighting point at master bedroom $105.00
Supply labour to install 45 light $450.00
Supply labour to install 3 ceiling fan (3 plate) $150.00
Supply labour to install 2 ceiling fan (5 plate) $110.00
Supply labour to install 1 hanging light $40.00
Re-instate wire at kitchen & 2 bathroom $480.00
Ceiling Works
Design & construct L-box **** c/w curtain pelmet $620.00
Design & construct L-box at dining c/w curtain pelmet $680.00
Design & construct L-box at Guest room c/w curtain pelmet $350.00
Design & construct false ceiling at Kids room c/w curtain pelmet $630.00
Design & construct false ceiling at passage way $200.00
Design & construct light holder at master bedroom c/w curtain pelmet $560.00
Solid surface
Supply & install est .25ft solid surface kitchen cabinet work top & vanity top with back splash $1,750.00
Miscellaneous Works
Haulage fee (uploading of material/sand & downloading of debris to MOE $250.00
approved dumping site) $80.00
Corrugated paper for (Protection) $250.00
Chemical wash upon works completion FOC
HDB Renovation Permit Fees
$37,820.00
Less: -432
Total: $37,388.00
