pessimizt
Cabinet Door (Join Cracked)
Hi all,
Anyone has any idea on where i can get a replacement of the cracked L-shape part ?
Tried asking a few hardware shops but they dont have.
The glass that was held by the frame was also cracked when it gave way.
Any where that i can get one by providing the dimension ?
I check with a contrator and he quoted me $100+ to replace the door. Said cant change the cracked part one.
Thanks in advance !
Edited by pessimizt
Check with Teck Cheong Alumn, Pang Giap and Alpha metals.
The insert is make of hard plastic, the quality is not that good in holding heavy weight like glass.
Maybe, get acrylic sheet and maybe you can use a piece of wood; cut to that insert shape to join your alumnimum.
Thank you GladysLim,
I have tried some strong bonding glue and then tape it with broad clear scotch-tapes and so far seems alright.
Will try your recommendation if it cracks again.
Have a great day !
