stormz14
Needed Advise On My Quotation Urgently
hi all,
please help me take a look on my quotation given by my ID, not very sure if the price is ex as compare to all of you.
Living & Main Entrance Amount
custom made 4ft full height shoe cabinet in laminate finish c/w casement & ABS triming $960
custom made 2ft settee c/w PVC cushion in laminate finish c/w cabinet & ABS Triming $460
custom made 6ft full height feature wall in laminate finish (designer piece) $1080
custom made 6ft TV console in laminate finish c/w drawer $720
custom made 10ft L -Shape Bar top in laminate finish $1600
custom made 7.5ft display cabinet in laminate finish with open shelves $1875
Master Room
custom made 6ft full height wardrobe in laminate finish c/w casement & ABS triming $1260
Supply labour and material to install TV Console? TBC
Supply Labour and material to install vender door c/w stopper, handles and lock $320
Bedroom 2
bedroom 3
Kitchen
custom made 16ft suspended bottom kitchen cabinet in laminate finish $1920
c/w casement door & ABS triming without Solid Surface
custom made 10ft top hang kitchen cabinet in laminate finish $1200
supply labour and material to create 1m x 0.55m wall support at kitchen door top $150
supply labour and material to install 10mm clear tempered sliding glass door $750
Master Toilet
custom made 6ft suspended vanity cabinet in laminate finish $720
Common Toilet
custom made 3ft suspended vanity cabinet in laminate finish $360
Miscellaneous
All carpentry with casement door c/w FOC Blum soft closing hinges FOC
kitchen cabinet will c/w 1 no. dish rack and cutlery tray FOC
hi thanks for the advise, just asking what you mean is it everything? then the market rate is around how much per feet?
hi...care to share who is yr ID? my kitchen is 10 bucks more than yrs per foot run.
Hi all
I need your advice on the quotation given to me below. Thanks!
A Design Services
1 Interior Design and Space Planning.
2 Furniture layout plan.
3 Perspective carpentry drawing.
4 Selection of color, material and accessories.
5 Consultation and project management.
6 Site co-ordination and supervision.
7 Decoration advice.
B Hacking Works
1 To hack off existing kitchen & 2 bathrooms flooring.
2 To hack off existing kitchen & 2 bathrooms wall tiles.
3 To hack off existing 50mm kitchen, fridge & washing machine base
4 To dismantle existing kitchen cabinets.
C Masonry Works
1 Supply labour & material to lay 300mm x 300mm heavy duty non-slip homogenous floor tiles for kitchen.
2 Supply labour & material to lay 600mm x 300mm homogenous wall tiles at kitchen area.
3 Supply labour & material to lay 300mm x 300mm heavy duty non-slip homogenous floor tiles for 2 bathrooms.
4 Supply labour & material to lay 600mm x 300mm homogenous wall tiles at 2 bathrooms.
5 Supply labour & material to lay waterproofing membrance for kitchen floor.
6 Supply labour & material to lay waterproofing membrance for 2 bathrooms floor.
7 Supply labour & material to construct 50mm kitchen cabinet base with side tiling.
8 Supply labour & material to construct 50mm washing machine base with side tiling.
9 Supply labour & material to construct 50mm fridge base with side tiling.
D Carpentry Works
1
Supply labour & material to fabricate 20ft designer's kitchen cabinet in laminate finish c/w ABS trimming casement door, 1 set of 2 tier stainless steel dish rack and cutlery tray.
2 Custom made 10ft(L) solid surface worktop c/w backsplash, sidesplash & front profile.
3 Supply labour to install cooker hood & hob.
E Doors/Gate Works
1 Supply labour & material to install acrylic bi-fold door at 2 bathrooms.
F Plumbing Works
1 Supply labour & material to run whole unit wiith stainless steel piping (cold water points only)
2 Supply labour & material to install concealed drainage pipe for kitchen sink.
3 Supply labour & material to install concealed drainage pipe for washine machine.
4 Supply labour & install kitchen sink & tap.
5 Supply labour to install 2 nos. wash basin & tap for 2 bathrooms.
6 Supply labour to install 2 nos. toilet sitting bowl for 2 bathrooms.
7 Supply labour to install 2 nos. toilet shower mixer for 2 bathrooms.
8 Supply labour to install 2 sets of instant heater or 1 set of storage heater.
9 Supply labour to install 2 sets of bethroom accessories.
G Painting Works
1 Supply labour & material to paint whole house interior & ceiling with Nippon Vinilex 5000.
2 Supply labour & material to paint door frames & pipes with Nippon Gloss paint.
H Miscellaneous Works
1 Supply labour & material to do chemical cleaning to whole house upon completion of works.
2 Supply labour & material to lay corrugated paper for protection upon completion of tiling works
Cost = $15888
Others
1 Supply labour & material to install propose false ceiling **** area. $1850
2 To dismantle existing wardrobe in 3 bedrooms $350
3 Design, fabricate & install cantilevered type of TV console/feature wall (6 ft) **** area. $1920
4 Design, fabricate & install cantiliver type of TV console/feature wall (4 ft) at master bedroom. $1280
5 Supply labour & material to install 4 units of classic door c/w complete iron mongeries at 3 bedrooms & store. (exclude door frame)
$800
6 Supply labour & material to install 1 set of 1/2hr fire rated door c/w complete iron mongeries at main entrance. (exclude door frame)
$1600
7 Supply labour & material to install 1 no. of casement tempered glass door at kitchen entrance. $700
Total Renovation Cost = $24388
Dear Friend,
I would strongly suggest you to engage a sub-contractor for hacking. You will find one if you google.
They charge you 40% of what the contractors generally charge. Just let them know at front that they cannot damage the window grills, bathroom window glass grill and cannot damage the doors. Ask them to guarantee that they wont damage the cornices , false ceiling if any etc. Otherwise have to pay you.
